P3D 4.4 11/28/18
Discussion in 'Prepar3D' started by Zed, Nov 27, 2018.
  1. Zed
    USA
    5,834Coins
    https://fselite.net/news/fselite-exclusive-p3d-v4-4-releasing-november-28th-pbr-confirmed/
    Changelog at the link but lots of new VR features and physics-based rendering are in.
  2. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Hi @Zed - Are you playing P3D in VR? If so, would you mind giving me some feedback on your experience in VR? (Or anyone else reading this for that matter)
    I ended up getting a refund after V4 was released as I could not get VR running smoothly on my system. I'm keen to see if this has now been improved?
    I've also upgraded my GFX card to a 1080 since I had Version 4.
    I mostly sim in Xplane now, but I have hundreds of $$$ tied up in ORBX / Aerosoft / Aircraft DLC for P3D that I would like to re-use again :)
    No VR = No play - for me.
    Thank you.
    (On the driving front I'm currently wasting away in ETS2, so good is the VR experience in that!!)
  3. Zed
    USA
    5,834Coins
    Hey Archie, I'm running P3D a lot and having a blast with it in VR. I ditched FlyInside, though. I just run P3D straight with its native VR now. 4.4. It is a little fiddly in that I have to start Active Sky, start SteamVR, start P3D, start SimTools, start JoinFS, start TeamSpeak, load a flight plan if I'm using it, and then enable VR (4.4 has this as a separate step and I really am glad they did this). Then I climb into my cockpit, put on the headset, recenter my view, and off I go. It's definitely a process. Maybe even a ritual. But it works and works well. Lockheed-Martin really improved things with 4.4.
    Hopefully that helps. Will DM you some stuff... ;-) Please let me know if any questions.
    145,148Coins
    +10,780 / 52 / -2
    Wow that sounds like a bit of a chore.
    How is the VR performance, any significant improvement or is it about the same?
  5. Zed
    USA
    5,834Coins
    It is a few steps for sure, but I’ve got the icons lined up on my desktop in order and just go down the line. I suppose I could script it but between Microsoft and Steam, I occasionally get hiccups with my sound and sometimes have to exit and restart SteamVR.
    The VR performance is very good but I can’t run with SteamVR's Motion Smoothing enabled. When taxiing it causes a flutter in the image of the leading edge against the tarmac, and when looking through the prop there is a visual flutter in the image of anything on the other side of the prop. Motion smoothing makes things really smooth though, but I run without it. Hoping for an update that fixes it. It used to work properly.
  6. RCFlyer
    RCFlyer Member
    138Coins
    I fly VR with the Oculus Rift in P3DV4.4 and it works well. There are still some areas where judder occurs, but, for the most part it works well. I use the native VR capabilities of P3D, not SteamVR. My PC is fairly strong though: 8700k @4.9 ghz, GTX 1080ti.
