Motor shaking juttering [Solved]
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by getti, Nov 12, 2018.
  1. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    One of my motors is juttering and shaking slightly as soon as I sit in the rig. I was thinking it was the potentiometer mount was too flimsy so I 3d printed better ones but that hasn't fixed the problem. Anyone one know what this could be? Bad potentiometer maybe? I'll post a video below.
  2. getti
    Canada
    45Coins
  3. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Is that a Hall potentiometer or normal one? Do you have another to try?
    152,676Coins
    +11,089 / 56 / -2
    It could be hardware, swap pots side to side to check, or interference, clip on ferrite magnets can help with the latter.
    It could also be PID settings.
    Is the computer set to English Local:
  5. getti
    Canada
    45Coins
    It's just a regular 10K potentiometer. I don't have another one here but I'm thinking to pop out today to the electronics store and pick one up.
  6. getti
    Canada
    45Coins
    Good idea I will swap sides now.
    What do you mean English Local?
  7. getti
    Canada
    45Coins
    I swapped the pots from side to side and somehow the problem is gone. I didn't have a lot of time but I'll do some more testing when I get home from work.
    152,676Coins
    +11,089 / 56 / -2
  9. getti
    Canada
    45Coins
    Ok I had a chance to test more and the problem is still there. I swap the pots from side to side but the shaking is still on the same side and it's even a little bit worse now. I thought I had some ferret clips somewhere but I can't find them. Any suggestions on what I can try in the meantime.
  10. getti
    Canada
    45Coins
  11. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    is it doing this in game ?
  12. getti
    Canada
    45Coins
    Yes it does it when I'm sat in the car, really annoying. Can't feel it as much when driving though.
  13. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    Whats your max min settings ? might be set to low causing movement where there shouldnt be ?
  14. getti
    Canada
    45Coins
    Max, Min? Tuning center values?
    I doubt it's related to Simtools cause the shaking happens even when the PC is off and simtools not running.
  15. getti
    Canada
    45Coins
    I think it might be from interference. I was moving some wires apart from each other and it seemed to make the shaking stop. Where do I put the ferrite clips, which wires?
  16. noorbeast
    152,676Coins
    +11,089 / 56 / -2
    Try ferrites on USB cables first.
  17. Thanos
    Electronics Engineer
    2,869Coins
    My opinion... you have ground loops.... disconnect ground of the potentiometer from the metal chassis, and the ground from the power supply (earth) from the motor drive gnd power input, only leave connected positive and negative leads from the psu...
  18. getti
    Canada
    45Coins
    I agree with you. I'm just confused which ground leads you're talking about? Also my rig chassis is made of wood, does that matter?
  19. Thanos
    2,869Coins
    Show your power supply and wiring in a video or photos...
  20. ne02005
    ne02005 Member
    Argentina
    105Coins
    How will be the ferrites on cables? do you have some picture? I have same problem too
