Showroom FlyPT - 6DOF Brushless DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by pmvcda, Aug 29, 2017.
  1. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    That sounds great. The load test will be very interesting. This may very well be the excuse I need to buy a 3D printer.
  2. Gadget999
    12,035Coins
    i ordered up a ESP32 - just trying to get it configured
    did you find any tricks to get it to count an interrupt on one processor and run the main loop on the other ?
  3. pmvcda
    15,533Coins
    For a small guide on using interrupts, take a look here:
    https://techtutorialsx.com/2017/05/09/esp32-running-code-on-a-specific-core/
    I have not tried yet...
    By default, it seems that all interrupts run on core 0 (https://www.esp32.com/viewtopic.php?t=3689), so we can use core 1 for other code (setup and loop run in core 1).
    So from above, it automatically separates execution in the two cores if we are using interrupts.
    EDIT: Also this link: https://www.hackster.io/rayburne/esp32-in-love-with-both-cores-8dd948
  4. pmvcda
    15,533Coins
    OK, changed the code to run the position function inside core 0.
    It works well.
    Is it faster? I don't know. But it should be.
    To use another core make something like this:
    Code:
    TaskHandle_t TaskA;
    TaskHandle_t TaskB;
    void setup()
     // Start runing tasks... (in any core we want, we can make a task for core 1 with higher priority)
     xTaskCreatePinnedToCore(
       TaskUpdatePosition,     // Task function code
       "UpdatePosition",       // Name
       10000,                  // StackDepth, size
       NULL,                   // Parameters
       2,                      // Priority 0=low high number=high
       &TaskA,    // CreatedTask
       0);                     // Core where the task runs (0 or 1)
       TaskGetSerial,          // Task function code
       "GetSerialInfo",        // Name
       NULL,                   // Parameters
       1,                      // Priority 0=low high number=high
       &TaskB,                 // CreatedTask
    void TaskUpdatePosition( void * parameter )
      // Must run task code inside loop...
      while (true)
        updatePositions(); // Code runing inside task
    void TaskGetSerial( void * parameter )
      while (true)
        getSerial(); // Code runing inside task
    void main
     // Some code runing in core 1...
  5. Gadget999
    12,035Coins
    thanks for sharing that :)
    its good that it defaults the interrupt onto one core !
  6. pmvcda
    15,533Coins
    Got some time,
    it works with 3 actuators! :D
    But I need to clean the mess :confused::
  7. pmvcda
    15,533Coins
    OK, I got some parts and started cleaning the mess:
    Well, more or less...
    One done, need another one.
    And 6 looms/cables...
  8. pmvcda
    15,533Coins
    1 of 6 made:
    I'm also printing the remaining parts to hold the actuators, since I got the base:
  9. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Very tidy engineering. Can't wait to see some load tests.
  10. pmvcda
    15,533Coins
    Well, I made it today:
    Used some weights to hold down sun umbrellas.
    They have 26kg each.
    Unfortunately, I had no space in the phone to make a movie, only pictures.
    I will repeat and make a movie, but the weight was a bit unstable.
    I had 3 weights, and it lift the 3 so 3 x 26kg = 78kg more than enough... :)
  11. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    That b&d workmate looks to be in just as good condition as mine ;)
    So you were lifting 78kg with one actuator? That's great! We'll get a sense of the speed when we see the video.
  12. pmvcda
    15,533Coins
    I have to say that I really love that Workmate. She was stored in the outside for 3 years, at rain and sun, but she's still useful, but I have to replace the wood...
    And, I made one of those stupid mistakes! :blush
    Until now, since I have been testing the actuators without big loads, I had no protection for the power supply, so in the hurry to see the results, guess what...
    78kg going down and some bad PID values = Lot's of EMF.
    So I have to send the power supply for repair :eek:
    What should I use? Diodes? Witch type and values?
    (Taken from: https://www.designworldonline.com/using-power-supplies-with-dc-motors/ or https://blog.uk.tdk-lambda.com/uk/2...-external-diodes-be-used-with-a-power-supply/)
    HELP! :eek:
    Motor specs:
    Power supply (in red):
  13. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Oh nooooooooo. Thanks for pioneering this new tech for those that hope to follow.
  14. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Any luck with that PSU? I've been following this development with great interest as have many others i'm sure. We should club together and buy you a new one so you can carry on and produce a reference design for us :)
  15. pmvcda
    15,533Coins
    The PSU is being repaired. Must get it this week.
    Meanwhile, I got some diodes, made the new cables, replaced the pots with resistances in the actuators, printed the supports for the actuators...
    Top mount:
    Bottom mount:
    Waiting for the PSU to make a new load test with video.
  16. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,944Coins
    Looks great. Not long now before I can justify buying a 3D printer. The 3D printed brackets/supports are a big part of the appeal of this build for me as many other actuator designs seem to require complex machined parts. Its also great that you can share the design as I have very little experience of 3d modelling.
    Tell me - does it use lots of filament to make blocks that big? Most of the 3d printed stuff I've seen is quite small. These look chunky. How does it equate in terms of cost of materials?
  17. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Thank you very much for the information . I am a bit transparent on the forum but I'm currently mounting a platform almost identical to yours with drive and similar engine and I had not imagined the return of tension. I'm reading you in time ... thank you!
  18. pmvcda
    15,533Coins
  19. Dirty
    All the way up front.
    7,957Coins
    Hmmm,....
    I calculated those values as well for my own design, but come to a different result:
    If you apply 0,6Nm to a SFU1605 they should reach a push force of 754N (75Kg). Or did I miss something? The speed of 292mm/s is correct though.
  20. Dirty
    7,957Coins
    ...could it be that you used the diameter (16mm) instead of the radius (8mm) in your calculations?
