Ordered a 3d Printer today
Discussion in '3D Printing' started by hjr2, Jul 18, 2018.
  1. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I found a good deal on a Monoprice Select Mini v2 and took the plunge. What software will I have to be learning to make parts?
    145,124Coins
    +10,779 / 52 / -2
  3. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,881Coins
    Is the monoprice select mini v2 a good option for a first 3d printer? I find the choice available to be quite overwhelming and i don't know who the reputable brands are.
  4. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I know how you feel. I've been perusing 3d printers for months now and couldn't make up my mind. It was a Prime Day special that showed up for $183, so I just jumped in . Worst case scenario, I can use this printer to make parts to make a better printer.
    Looking forward to some of the projects I've seen out there, and learning to make my own parts, tools etc.
  5. PiaMan
    PiaMan Active Member
    Saskatchewan, CANADA
    607Coins
    3DOF, DC motor, SCN5, Arduino
    Also you will likely need repetier-host to transfer your new designs to the printer.
    And a cheap micrometer to measure if you are designing your own parts.
    And if you havent already head over to thingiverse to start downloading designs that are ready to print
  6. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I gotta tell ya boys. I'm hooked.
    IMG_1482.JPG SO far I've printed a box for my arduino and adafruit motorshield from here. Any setup tips to reduce those stringy fuzzies you see would be appreciated. https://www.thingiverse.com/thing:2781281
    A clamp wrench to crank down the Logitech DFGT https://www.thingiverse.com/thing:2425190
    A GT2 Pulley that failed, then one that worked. I tried streaming the gcode for the failed part via USB. I'll just stick with the SD card for now. It is interesting to see the internal structure, and how it's adjustable. What a time to be alive.
    I have downloaded Fusion 360 and OpensCad. I can't describe the amazement I felt and still feel watching these things work. I imagine a future where manufacturing can be done from home and the plastic polluting the oceans can be farmed and recycled into new materials over and over. Just imagining.
  7. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    It also looks like my dream on having a dremel based CNC will come true because of this printer.
  8. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I ran out of PLA and picked up 1kg of ABS and 1kg of PETG. They are noticeably more difficult to work with. I switched to blue tape with the PETG and ABS with better results than the tack paper or whatever came with the printer.
    Made a couple holders for my Dayton Audio pucks. A big improvement over mounting them on a board and screwing it to my chair.
  9. bruce stephen
    general contractor
    michigan
    9,110Coins
    petg is my go to filament.
  10. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    If you have any tips for printing PETG, let me know. I’ve been struggling getting the bed level and temperatures right. After reading a bunch of articles I get the sense it needs a little more space between the nozzle and bed, and temps around 230-260.
  11. pmvcda
    14,210Coins
    I find PETG easier than PLA.
    I'm no expert, but I usually achieve good results in my printer.
    Usually I use Devil Design PETG and my settings are:
    Blue tape in bed
    For the material:
    Diameter 1.75
    Flow 100%
    Initial layer:
    Print @ 240ºC
    Plate @ 80ºC
    Print speed 30mm/s
    Next layers:
    Print @ 235ºC
    Plate @ 75ºC
    Print speed 60mm/s
    Layer height 0.2mm
    Shell thickness 1.5mm
    With Print cooling
    Plate Adhesion with Brim of 6mm
    Hope it can help.
  12. bruce stephen
    general contractor
    michigan
    9,110Coins
    i use hair spray on glass for adhesion. I'm printing .3 mm layers for most parts. I print a little hotter at 255c on the hotend and a 95c bed. i use the cheap petg from micro center.
    I use an old business card to set the height of the hotend manually after spraying and mounting the glass to the bed. i have about five pieces of glass that are the same so i only have to swap the glass if the print doesn't start well or if i am printing a number of parts.
    if the part has a smaller footprint and can finish in less than a hour a brim usually isnt needed. but for parts with a large footprint or that take more than three hours I use a brim.
  13. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,881Coins
    The time has come !!
    3D printer for christmas. Someone has recommended the Ender 3. £200 in the UK sounds great . I was prepared to pay up to £400. What more would I get for my money if I paid up to £400? Do you think I'd regret going cheaper or is it perfectly adequate for making small things like gears, brackets, spacers etc
  14. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    Twice the money must mean a little better at least. Better materials and workmanship perhaps. If you can find something that has auto bed levelling, go for it.
