My 6DOF project
Discussion in 'DIY Motion Simulator Projects' started by xiatian, Jul 9, 2018.
  1. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Prepared for a long time, only now, I don’t know if I can finish it.
    145,034Coins
    +10,776 / 52 / -2
    By nature projects can be impacted by other things in life. Even if a project is not finished it is likely you have learned a lot about the theory, hardware and software involved in motion simulation.
    But do try to not be overwhelmed and do keep your goals and expectations realistic, in my view that is the best way to keep a project alive, even if it needs to be delayed for a while or go down a redesign path.
  3. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Some parts that have been obtained
    145,034Coins
    +10,776 / 52 / -2
    That is an impressive collection :thumbs
  5. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Thank you noorbeast, I know I want to continue
  6. sam poole
    sam poole Active Member
    midlands
    34Coins
    I would love to get my hands on all those parts its hard work getting the parts together so you have done a lot already just concentrate on 1 thing at a time and before you know it it's done
  7. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Thank you, sam poole, I will continue this project.
  8. stargazer
    stargazer Active Member
    Electrical/Computer Engineer
    Boston,USA
    811Coins
    3DOF, Arduino, Motion platform, 4DOF
    Xiatian
    I wish you the best. Your success will be my inspiration. I always want a 6dof but chose to do a 3dof instead to get my feet wet first. I will watch your thread closely so please post as much as you can. Even something trivial could turned out to be very helpful for some beginner to learn and understand the build process.
    Regards
    Stargazer
  9. bruce stephen
    general contractor
    michigan
    9,110Coins
    dont give up. I havent been able to do anything on my rig project due to life (a very busy, busy season). but the stuff will be waiting when I get to quit working all the time.
  10. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Thank you, bruce stephen, stargazer, I will
  11. pmvcda
    14,203Coins
    I,
    Can you show what motor and controller model you are using? Specs?
    Without knowing, I don't know if you can use my solution.
  12. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    it is this
  13. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    86 series brushless motor 440W3000 to 48V supporting BLD-750 driver
  14. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Find a big one
  15. pmvcda
    14,203Coins
    This one? https://pt.aliexpress.com/store/pro...l?spm=a2g03.10010108.1000023.1.266a6e8efDPqoL
    and https://pt.aliexpress.com/item/48V-...Motor-series-for-CNC-Machine/32593792750.html
    Then it's compatible.
    You should be able to use the hall sensor version.
    Only difference is the motor with 8 pole.
    Instead of 18 steps per turn you get 24 steps per turn.
    Can you make the motor work without ESP32, just using the controller pot to adjust speed?
    Maybe follow those videos just to be sure the motor and controller are working:
    To control the motor with PWM, you have to set the controller switches to: SW1=off SW2=on.
    Just follow the connections in my thread and it should work (first page - electronics updated yesterday).
    Test with one motor. Use the code I have right now for the ESP32 (today, because I'm going to update the code to use my interface).
    Change the number of motors to 1 in the code.
    Use simtools to test. Be sure to have the right settings on the simtools interface.
    Also, the code expects you to have the limit switches.
    It should start looking for the minimum switch, followed by the maximum and only then it will connect to simtools to follow it's commands.
    I explain everything in my thread. I think it's well documented.
  16. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Hello, set sw2=on, code #define NUMBERACTUATORS 3 // Number of actuators (for one board) is changed to 1, the motor is high speed after power-on, and the micro-switch does not respond.
    When uploading the code, the prompt ''Found invalid library'" AzureIoT, open the file is empty, is not because of this problem.
  17. xiatian
    xiatian Member
    Xi'an, China
    262Coins
    Find invalid library
  18. pmvcda
    14,203Coins
    It should make the motor move until the minimum switch is pressed.
    But I found some problems:
    -I took another look at the specs. the motor is 120º, so switch 2 should be OFF (sorry)
    -Try with switch 1 ON. The RV pot when turned, should not change the motor speed.
    -Also, try to change this:
    Code:
    #define PWM_FREQUENCY 5000
    to
    Code:
    #define PWM_FREQUENCY 2000
    In the datasheet, it says to use between 1 and 3 KHz, for pwm, so let's use the middle one.
    Library:
    Did you install everything in the Arduino Interface?
    You can follow this tutorial:
  19. pmvcda
    14,203Coins
    Also change this:
    Code:
    // Main loop
    // Here we get the simtools commands and make the actuator move
    void loop()
      // While we are here, nothing else runs on the background...
      while(true)
       getSimToolsCommands();
       updateActuator(0);
       updateActuator(1);
       updateActuator(2);
    // Update positions thread loop
    // This thread updates the actuators positions reading the hall sensors
    void TaskUpdatePositions(void * parameter)
      while (true)
       updatePositions(0);
       updatePositions(1);
       updatePositions(2);
    to:
    Code:
    // Main loop
    void loop()
      while(true)
       updateActuator(0);
      while (true)
       updatePositions(0);
    It's calling the other 2 actuators...
  20. pmvcda
    14,203Coins
