12 v wiper motor fix.
Discussion in 'Motor actuators and drivers' started by Tags..(VR), Jul 8, 2018.
was there a better way to handle this problem?
  1. yes , you should of left the circuit board the way it was.
    0 vote(s)
    0.0%
  2. no , you took the right measures to fix this issue.
    1 vote(s)
    100.0%
  1. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    After picking up these 12 DC motors i was having issue figuring out what plug works for what. talking it apart and finding a circuit board inside and things being in reverse . I decided to attack this issue with a Hammer .
    i ripped out the circuits leaving the essentials and soldering in direct wiring for the fastest speed on these two speed motors. circut board fix 1.JPG circut board fix 2.JPG circut board fix 3.JPG
  2. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    This is two Dc motors of possibly of six for 2 Dof to 6 Dof. next will be working on getting the pots afixed some how ?
  3. sam poole
    sam poole Active Member
    midlands
    30Coins
    You don't want it at the fastest speed needs to be the same speed when polarity is reversed also the casing will need isolating from the circuit
  4. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Interesting. I did notice the speed in reverse was the same speed but being the newb here , I love the setup you have and want to go your route with 6 Dof. right now still learning and soaking up everything i can as a sponge.
    the isolation of the case is kind of confusing to me? should i be , use ground the case separately along with the regular two wire setup ? Im not sure , i don't want to burn up the motors and guess i need to do much more investigating.
    anther question is whats the right way to connect the pots to the drive? I guess little steps are to be the right way to go .
    i thank you for your input and welcome more as you give it.
    i have some many question and only have the sorting through forums and videos to watch . Thanks Sam
  5. sam poole
    midlands
    30Coins
  6. sam poole
    midlands
    30Coins
    The pot mounting is a headache I don't think my concept would work for you but there are plenty of good examples just have play
  7. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Thanks for the quick reply, i open the motor and trying to go by the diagram you gave me and was going to ask that what you have said, next. but really im curious of how you attached the extension arms to the motor arms? with rod end bearings?
  8. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    I was looking at the cost and there kinds high but if needed then thats what it costs. just trying to piece things together without making to many costly mistakes.
  9. sam poole
    midlands
    30Coins
    The route I went down was to use the existing ball on the wiper arm to attach a ball socket to you probably have 13mm ball on the end of yours then attached threaded rod to it
  10. sam poole
    midlands
    30Coins
  11. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    I had to run and look for some holding brackets for the motors , hope they work and thanks for the link to sorting out the ground issue. it doesn't exactly match my motors but theres only one wire that i see leading somewhere else. i havent cut anything yet, just want to be really sure before going forward.
  12. sam poole
    midlands
    30Coins
    Do you have a multimeter?
  13. sam poole
    midlands
    30Coins
    Basically from this picture you want to solder 1 wire to red and 1 to blue discard yellow the blue uses the case as it's wire and thats the thing you dont want so this would be the one to cut then make sure there is no continuity between each wire and casing how you achieve this is up to you I just soldered both directly but you only need to do the blue as the others are naturally isolated
  14. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Yeah i have a multimeter. i used a light diode to find that it was case grounded. i didn't think of the multimeter.
  15. sam poole
    midlands
    30Coins
    Oh good well glad you're on the right track I'm no pro still learning just more software side of things now but anyway all the best with the project will be interested to see what you produce it's well worth the effort
  16. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Thank man for the help. i sure hope i can bend your ear in the future.
  17. sam poole
    midlands
    30Coins
    No problem always keen to help where I can but there are many more experienced here which will give you a broader sense of things there is some really amazing stuff on this site
  18. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    I agree ...................thanks
