Motor requirements.. Would this work?
Discussion in 'Motor actuators and drivers' started by cauehawaii, Apr 23, 2009.
  1. cauehawaii
    cauehawaii New Member
    3Coins
    hello guys..I found this motor for sale
    http://produto.mercadolivre.com.br/MLB- ... -polos-_JM
    Would it work fine with Thans H-Bridge and AVR controller?
    Any problems that I should address the PCB maker or go for another motor?
    # Potência: 1/2 cv
    # Carcaça modelo: Nema 56
    # Diâmetro do eixo: 19 mm
    # Tensão: 110/220V
    # RPM: 3470
    # Corrente nominal: 110V = 7,6 Amperes / 220V = 3,8 Amperes
    # Peso: 10 Kg
    # Diâmetro da embalagem (CxLxA): 300 X 150 X 180 mm
  2. tronicgr
    tronicgr
    No, This motor is AC and works with high voltage 110V/220V. It requires special VFD driver controller to drive it like servo motor (really expensive!) :tape:
    You can use only small DC motors with DSMhb1.2b (No more than 24V or 25A current).
    Thanos
  3. cauehawaii
    3Coins
    thanks for your help man
    What would be the choice if I used that motor? I am afraid that a 24vdc motor wont be enough for my layout.
    I also saw there were other requirements on the motor such as position feedback, different speed. I am worried to spend money with the wrong motor. H-Bridge is already ordered but I would consider another option if I could use a strong motor.
    thanks
    Caue
  4. cauehawaii
    3Coins
    I found a list of bosch wiper motors, perhaps it can be useful for someone
  5. RaceRay
    Hamburg, Germany
    23,884Coins
    Could you describe your layout more, so we can estimate if wiper motors fit or not?
    Maybe a sketch?
  6. cauehawaii
    3Coins
    thanks for the answer
    please check my layout attached. I am building it in aluminum to keep it lighter. The base support is based on cska system (update - CHANGED TO MORE OF A FREX KINDA OF SYSTEM).
    I will be glad to hear any thought about it.
    thanks
  7. cauehawaii
    3Coins
    perhaps this is interesting for someone as well..
    I just found the motor from a Scania truck listed on the Bosch pdf above for sale online here in Brazil.. it is a 24vdc wiper motor... around 60US$ brandnew plus shipping..let me know if someone need help translating something from the website..
    http://www.autotavares.com.br/Produto.a ... toId=25119
    here is a complete list of their motors available..
    http://www.autotavares.com.br/Loja.aspx ... upoId=1534
    I am still researching a lot about motors not to make a mistake with them...
    so far this is the 24vdc most accesible..any problem with it?
    Bosch CEP Wiper Motor
    Tension: 12 VCC ou 24 VCC
    Consumo Nominal: 7,5 A (as per torque)
    Torque/options: 25 a 48 Nm (Torque máx.)
    Sentido de Giro: L/R
    Speed: 1 ou 2
    Maximum rotation: 100 rpm
  8. Senetor
    Senetor Member
    Australia
    595Coins
  9. cauehawaii
    3Coins
    thanks man, i saw this post a little while ago but couldnt find again, certainly there are a lot of good information there for me as my setup is similar. .. I was just thinking about substituting some of the gearings for pulleys and steel cables similar to Thanos cockpit... I have got the aluminum bars and they are very light... in the next 2 days the cockpit part should be ready...
    waiting for my pcb boards to get here...I hired someone to do it for me...out of my league to build them... just hope there are no problems when they arrive... they said they would test it, and it should be almost 'plug and play'.. lets hope so...I will post some pics when they arrive..
    ahh btw.. we have to import all the components so it should take a couple of extra weeks...in the meantime I am working on the structure and motor to use.
    Aloha
  10. cauehawaii
    3Coins
    I just bought two wiper motors 24V for scania trucks on the website above that I posted earlier. I will do some tests when they arrive and I will post a video/photos. I am changing my layout similar to youbuddy´s layout (yobuddys-motion-simulator-t625.html), if worked for him it will work for me.
    I am just worried with the PCBs now.
    If I have problems when they arrive, can I use a Basic Stamp2 and 2xHB-25 with the 24V motors? at least to get them working before I find someone else to build new boards for me?
  11. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    Which Power Supply do you use for the 24V Wipermotors?. Two 12V car batteries in lines up switched?.
  12. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Yep, two 12V batteries in series = 24V
  13. cauehawaii
    3Coins
    thanks for the previous post about the batterres.
    Below a few pics from my Motor that just arrived
    I would like to make a newbee question... the plug in the motor is for power, correct? What are the cables that go to the H-bridge?
    some pics of my aluminum layout...it is very easy to work with aluminum... and it is very strong...on monday I will work on some improvements and I will install the universal joint on the seat...
    I am still waiting for my boards...we had to import some coomponents..so it should take some extra week to get it done..
  14. cauehawaii
    3Coins
  15. christian
    christian Member
    Germany/München
    967Coins
    2DOF, SCN5, SimforceGT
  16. cauehawaii
    3Coins
    Thanks Christian..I tried some babelfish on the german text and it was a good lesson.. I will keep researching some more not to make a mistake with the electrical part and burn my boards or motors...
    feel free to send anything you may find useful...
  17. cauehawaii
    3Coins
    I am thinking now about buying the power supply below
    switched-mode power supply:
    * Manual Selection (127/220VAC)
    * Manual selection 350W 24V
    * Maximum current de 8A
    * 3 conectos for distribution
    https://www.mercadodopovo.com.br/loja/p ... 01W_24V_8A
    I know my motor is a 24Vdc and max 9A. Can I use switched-mode power supply ?? like the one above? Any recommendation for power supply???
    I am also done with my universal joint below
    Regards
  18. cauehawaii
    3Coins
    Just purchased the following Power Supply. I hope it works :)
    Switched Power Supply Stabilized 201W 24V 8A
