New Simxperience stage 1 kit, I dont know what I am doing?
Discussion in 'SimTools compatible interfaces' started by ghetto, Apr 25, 2012.
  1. ghetto
    ghetto New Member
    - 11Coins
    Hi all,
    My stage 1 SNC5 kit arrived from simxperience I have tested it using their commander 2 software, (commander 3 will not install) with Dirt 3 and all seems to be good..But I really want to use this for Microsoft Flight Sim X.. Simxperience does not support this tittle so I was hoping I could install X-sim and use one of the FSX profiles from you guys.. But when I download Xsim it takes me to the community addition alluminium, which I have installed.. When the software runs the actuators move into I guess a home position.. But for the life of me I cannot figure out how to download a profile and get it running with the game..
    Help would be appreciated..
  2. bsft
    You will probably have to write your own profile.
  3. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    The only known installation issue with Commander 3 is that it will not install on a hacked or wacked version of Windows 7 because the latest WIndows Updates are required.
  4. Corporatezombie
    Corporatezombie Member SimAxe Beta Tester Gold Contributor
    Leicestershire
    148Coins
    3DOF, SCN5
    I have a Simexperience stage 1 and traction loss running through their SX4000 box.
    I think I have it running correctly through simtools but I'm not sure!
    No changes to wiring or connections were required (phew!)
    For info my settings are:
    I have Axis assignments as:
    Axis 1 DOF1 checked, sway 0% DOF2 Checked Surge 60% DOF3 blank, DOF4 Checked, Roll, 50% DOF5 unchecked Pitch 50%
    Axis 2 DOF1 unchecked, sway 0% DOF2 Checked Surge 60% DOF3 blank, DOF4 unChecked, Roll, 50% DOF5 unchecked Pitch 50%
    Axis 3 DOF1 Checked Sway 40% DOF2 blank DOF3 checked Yaw 50%
    Axis Limiting all set to 90%
    Interface settings:
    Interface 1 Com3 packet rate 10 Axis 1, speed 10 accel 500
    Interface 2 Com4 packet rate 10 Axis 2, speed 10 accel 500
    Interface 3 Com5 packet rate 10 Axis 3, speed 10 accel 500
    This might help someone in the future!
  5. stashy
    stashy Member Gold Contributor
    india
    - 238Coins
    2DOF, SCN6
    hi im using scn6 with sx-4000 i see two assined axis id 0 and 1 waht do i select there?
  6. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
  7. stashy
    india
    - 238Coins
    2DOF, SCN6
    also i seem to be able to get only one actuator moving
  8. stashy
    india
    - 238Coins
    2DOF, SCN6
    got two working now :))
