  1. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    Welcome @Nellrolandmosselbay.
    I look forward to hearing more about your project plans.
    Check out the FAQs: http://www.xsimulator.net/community/faq/
    We have a glossary for all those acronyms we tend to use, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    When you are ready please start your own project thread here and show off your current setup, plus add updates or post any questions: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    On your thread you can start a discussion about the DQ860MA, as I don't recall anyone using them.
    Same with triples Vs VR, start a discussion on your thread, though it really is a matter of preference.
    Good luck with your project
  2. Nellrolandmosselbay
    Nellrolandmosselbay New Member Gold Contributor
    South Africa
    87Coins
  3. gzresident
    gzresident New Member
    China
    - 38Coins
    say hi to all, and thank you who created and run this site.
    153,788Coins
    +11,150 / 57 / -2
    Welcome @gzresident.
    You will find a knowledgeable and helpful community here who freely give of their time and expertise.
    If you are seeking build, hardware and software information to get you started, then look in the FAQs: http://www.xsimulator.net/community/faq/
    When you are ready please start your own project thread in the appropriate thread section.
  5. yogi149
    yogi149 New Member Gold Contributor
    engineer, sim-controls for helicopter
    Aachen, Germany
    258Coins
    Hi Roland,
    welcome here.
    can you confirm the torque you are calculating with?
    The strongest NEMA 42 stepper I can see generate 4100 [Oz - in], that match nearly 29 [Nm].
    Your 300 kg per inch match nearly 390[Nm], that seems to high in my opinion.
    (don't know where to post this else, sorry)
  6. gzresident
    China
    - 38Coins
    I am from China,actually I want to introduce my project which similar to YAW VR, China gov block the web make it very slow and can't use youtube,maybe I can try upload some pictures on a new post.
    I am using this wheel.
    153,788Coins
    +11,150 / 57 / -2
    You can start a new thread of your own in the Commercial thread section and add details, as this thread is for welcome introductions only: https://www.xsimulator.net/community/forums/commercial-simulators-and-peripherie.52/
  8. mo-wills14
    mo-wills14 New Member
    Ontario, Canada
    186Coins
    Hi everyone! I'm Morgan, from Ontario Canada. I've been reading through the forums and member projects here for quite some time, and finally decided to join the community. The amount of information here, and members that are eager to help each other with their projects is amazing! I look forward to being a part of it, and hopefully I'll be able to contribute to it as well.
    I'm currently in the early stages of building a racing/flight sim rig, using a fuselage from an old aerobatic biplane (hated seeing it rotting away out in the weather, so I had to rescue/re-purpose it). Planning on a G seat to start, and full motion eventually. I'll start a build thread soon to document my progress as I go.
  9. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    I'm Matt for Oz, I've been quite active in the iRacing forums for the past year or so, quite a humbling experience to start here as a forum n00b with no coins !
    I have an interest in open wheelers, F1, Indycar and OSW.
    On the iRacing forum I have numerous posts on Kollmorgen "bogeyman" servos, SinCos encoder upgrades and bass shakers. Drop me a line if you need any help with the above !
    Long-term my goal is 4 or more degrees of freedom, perhaps 4 vertical actuators + yaw + surge/sway.
  10. FIDDLE72
    FIDDLE72 New Member
    LE MANS
    153Coins
    3DOF, Arduino
    I'm 60 years old, I teach technology in high school and I am pilot-instructor of ULM Multiaxe (very light aircraft)
    I live near Le Mans in France and I would like to introduce students to piloting within the framework of the school with a simulator whose movements would approach those of a plane.
    I have browsed forum, incredible richness, and I am convinced that technically I am able to engage a 3DOF project at least, with the software Sim Tools
    For the associated simulation software I have not yet decided between Flight simulator and X Plane. In any case there will be three screens at least that I would like to fix on the dynamic simulator.
    Thank you very much, in advance
    Best regards
    Fiddle72
    153,788Coins
    +11,150 / 57 / -2
    Welcome @mo-wills14 , @AussieSim and @FIDDLE72.
    You will find the members here give freely of their time and expertise.
    Good luck with you build projects.
  12. boomer
    boomer New Member Gold Contributor
    Sydney, Australia
    170Coins
    Hi everyone,
    I'm Kas from Sydney Australia. I play fair bit of racing simulators (iracing, AC, RR3E) and also flight/space simulators (DCS/X-Plane & ED). I currently own 2DoF motion simulator from motion systems (http://motionsystems.eu), which im no longer happy with and currently looking for some help in building or advice in if i could butya pre-build packaged 4DoF or 6D0F simulator.
    Unfortunately im not that handy at starting my own project as many people have done here. I can do modifications and tweaks but thats about it. I hope i have come to the right place.
    Thanks.
  13. noorbeast
    153,788Coins
    +11,150 / 57 / -2
  14. piloulou
    piloulou New Member
    103Coins
    bonjour mon nom est philippe Je vis en France désolé pour mon mauvais anglais , je découvre le forum avec un grand plaisir que
    je cherche à faire un simulateur 2 ddl et j'espère trouver mon bonheur avec vous à
    bientôt
    153,788Coins
    +11,150 / 57 / -2
    Welcome @piloulou
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
    Good luck with your project.
  16. BlumCore
    BlumCore New Member
    100Coins
    Hello Togheter,
    First i have to say sorry for my bad english.
    I am 17 comig from Switzerland. My Boss and i want to build a 6 DOF Motion Platform. He wants it for Paracticing the Nordschleife for VLN. I want it just for Fun.
    Best Regards
    Yannik
    153,788Coins
    +11,150 / 57 / -2
    Welcome @BlumCore.
    If you are seeking build, hardware and software information to get you started, then look in the FAQs, there is even a 6DOF section: http://www.xsimulator.net/community/faq/
    You can even build your own DIY actuators: https://www.xsimulator.net/community/faq/diy-linear-actuators.248/
    Good luck with your 6DOF project.
  18. willv
    willv New Member
    107Coins
    Hi I'm willv
    I just found out about this and it looks like I may finally use my Arduino.
    I'm in the process of building my own steering wheel add-on for G27 (6 buttons are not enough anymore).
    After that I may experiment with some motion sim as well.
    Cheers
    153,788Coins
    +11,150 / 57 / -2
    Welcome @willv.
    You have come to the right place, there is a really active community here who freely give of their time and expertise.
    You will find plenty to get you started in the FAQs, including a section on peripherals: http://www.xsimulator.net/community/faq/
  20. francabrera
    francabrera New Member
    córdoba
    271Coins
    Hello, I am new to this forum, first thank everyone for the work and dedication. I have made a 3dof simulator and now I want to update it. This text is translated from google. I am Spanish and I do not know English.
