Showroom Constructing a "seat mover"
Discussion in 'DIY Motion Simulator Projects' started by Michael898, Feb 28, 2018.
  1. Michael898
    Michael898 To build or not to build.
    Welder
    Holland
    117Coins
    I am Michael from the Netherlands.hug:
    I have NO experience in electronics, i am a welder (steel,stainless steel and aluminium).
    I am going to try and build a seatmover because of the thight space in my "manecave;)"(attic).
    My goal is to move my seat with 2 wipermotors and 2 motormonsters in a space not bigger then 1x1 meter max..(with as less money possible for me)
    I have been looking for parts some time now, and found 2 wipermotors from a truck (24v) at my work for free.
    I bought 2 motormonsters and a arduino uno clone via ebay.
    A friend had 2 pots laying around...
    Already got my gamingseat.
    So...
    Everything is going good so far...
    I welded a base and a universal joint.
    I contructed 2 "boxes" to hold the motors and pots...
    I will bold the u-joint and the motor boxes to the base because this way i can change thing easy-er...
    I will take pictures from the progress and post a update when i have done something...
    I hope you enjoy this tread...:popcorn
    (that's a lot of I's;))
  2. ferslash
    ferslash Active Member
    4,798Coins
    pics, pics, pics pics :popcorn
  3. Michael898
    Welder
    Holland
    117Coins
    This is my base...
    sawed from 60x40x4 mm aluminium. top plate is 10mm thick.
    Why the angled front??? Because i can:thumbs and , i think it looks good!
  4. Michael898
    Welder
    Holland
    117Coins
    on the way ! hahaha enjoy.
  5. Michael898
    Welder
    Holland
    117Coins
    And then the universal joint...
    Stainless steel tig welded...
    top and bottom plate 10mm thick...
    Made to bold-on...
  6. Michael898
    Welder
    Holland
    117Coins
    The 2 "motorboxes" i constructed...
    The boxes are made from 3mm steel tube.
    Also bold-on...
  7. Michael898
    Welder
    Holland
    117Coins
    The "boxes" will be bolted between the top and bottom like this... IMG-1359.JPG IMG-1360.JPG
  8. Michael898
    Welder
    Holland
    117Coins
    as for the electronics...
    I printed some housings for the 2 motormonsters and the 1 arduino...
    i designed them to mount a 80mm fan on top for cooling...
  9. Michael898
    Welder
    Holland
    117Coins
    I hope you liked this sofar..
    next up is to measure my gamingseat COG (center of gravity ,i believe)and mount it to the base with the uni-joint...
    then the "motorboxes" fitted with the pots...
    i will update this tread when i did something new..
    • Like Like x 6
  10. Michael898
    Welder
    Holland
    117Coins
    WoW. That’s fast. :cheers
    I applied for a free licence.
    And got iT!!!
    I like how this build is going with help from here!!!:)
  11. bruce stephen
    general contractor
    michigan
    9,110Coins
    Nice looking rig. It reminds me of a stealth fighter. I would suggest heatsinks on those monster motos, I do like the big fan tho.
  12. Michael898
    Welder
    Holland
    117Coins
    Thanks Bruce. Stealth fighter.mmm...
    Let me think of a name for the Sim...
    I was planning to use heatsinks but i neef to cut them in half
  13. kanuk
    kanuk If it ain't moving, it ain't simulating...
    Eng
    Melbourne Australia
    2,380Coins
    That is some very nice welding @Michael898
    I'm eager to see how it turns out. Well done sir
  14. ferslash
    4,798Coins
    :cool: this thread is full of "showing off"....
    *** keep that way :D:D:D:D :thumbs
    fer
  15. Michael898
    Welder
    Holland
    117Coins
    Sorry, but i like iT alot. Hahaha:p:cool:;)
  16. FargusFaustmeister
    FargusFaustmeister Member
    Engineering Technologist
    69Coins
    I really like your base. How did you cut the stock? Plasma or cutoff wheel, something else? This is a very clean build and I like that you're aiming to keep it within such a compact footprint. Great stuff :)
    I'm still getting all of the sim configurations figured out so I gotta ask; what motions are you planning to simulate with this actuator setup? Pitch, maybe some yaw-ish motion?
  17. Michael898
    Welder
    Holland
    117Coins
    Hi
    I used an anglegrinder for the funky parts an a "stationary circular saw" for the rest. (see picture, i don't know how its called in english).
    As for motion : i am aiming for nice sharp crisp movement. not the big sway's left and right... just enough to feel the lean abit... My lever on the motor is 35 mm center/center so about 70mm up/down.
    But i LOVE the gear changes and curbs alot:thumbs
  18. FargusFaustmeister
    69Coins
    You've got a lot of skill, that autoCAD drawing is very nice. I'm hoping to snag a copy of Solidworks for my work, but drafting is always the way to start. I think we're going for the same thing (short sharp motions) so I'll be watching your project closely! I too like the gear changes :D
    Since your platform is quite high what do you plan to mount your controls to?
  19. Michael898
    Welder
    Holland
    117Coins
    For all you 3d printer people...
    Here are the stl file's i made for the monstermoto and arduino uno R3
    There is a "fork thingy" in it...that's how i gonna move my pot.
  20. Michael898
    Welder
    Holland
    117Coins
    I like to sketch up first to prevent me of making it to big/funky/crazyo_O:)!!!
    I learned how to draw myself with autocad first...then i went for solidworks... But then i found Inventor,and sticking with it!!!
    My plan is to leave the pedals and steering wheel where they are... they are not fixed to the sim... (my little man wants to play to;)).
    AND i have no space for a full sim...
    IMG-1364.JPG ps (maybe i am going to fix the pedal/steer/shifter to my sim when i make my Tracktion loss) but i try this one first...:thumbs
