MMOS controller with cheap servo drive and motor
Discussion in 'Direct Drive Wheels' started by sikjar, May 22, 2017.
  1. Gadget999
    12,007Coins
    i suggest you use a DC motor and a IBT-2 motordriver - you can use a arduino leonardo or a STM324f Discovery to control the Motor
  2. MegamanAT
    MegamanAT New Member
    Austria
    157Coins
    they are accepting digtal pulse and direction and analog (position mode) and -10 +10v analog (torque mode)
  3. MegamanAT
    Austria
    157Coins
    yes, probably the only way for a cheap solution.
  4. MegamanAT
    Austria
    157Coins
    But I realy don't see the benefit of a 5-6nm dd-whell. That's about the level of a T500RS... A 12nm stepper or 20nm servo would be much better in my opinion.
  5. Gadget999
    12,007Coins
    if you find time - there is a video of a guy who is a racing driver and he tries out the osw
    first thing he does it reduce the ffb strength so the wheel feels more realistic
    i think it was reduced to approx 30%
    I have a dc motor from a winch - it looks like it would dislocate my arms !
    starter motors are several kw iirc
  6. wsx820919
    wsx820919 New Member
    american
    182Coins
    In fact,in the "Son of OpenSimwheel - An Experiment" page 1 videos It has been given to everyone Enough clues about design stepper wheel,People who have used stepper should know,when the stepper motor running but locked the rotor,the rotor must be Happen torque impact,This is a need to overcome,but,how do this,The rotation of the magnetic field is the key,when the stepper motor running but locked the rotor,but The motor controller is still continuing to input PWM,The magnetic field is still spinning,the rotor will be between have torque or have no torque cycle ,therefore used the encoder,encoder followed the position of the rotor,then controller KeepThe magnetic field of the first or next shot in the direction of rotation at any time,And then according to the duty cycle by stm32f4discovery PE9(MMOS),Real time change of current,This is probably the idea of development,I'm trying to do something about it。。。
    PS:Please forgive my bad English.....
  7. henrique fernandes
    henrique fernandes New Member
    melbourne vic
    188Coins
    is this project dead? I`m also thinking about using these Chinese cheap drivers+stepper because the budget is a strong limitation for me LOL.My idea is to buy a NEMA 34 of 8.5NM and driver, which I found for 180 aud on ebay, but I don't have any hardware yet
    I read the whole topic and a possible issue that you guys have found made me think about a different technique to control the torque. One was thinking that the power supply was too weak, and because of this, the motor had no torque. Don't you think this can be the solution?
    what if we use this PWM out of the DISCOVERY to control the voltage supply on the "cheap driver"?
    my idea is to use the PWM direction on the driver to set the correct direction and the PWM signal we could reduce the voltage on the power supply pins of the Driver.This way for a low-intensity effect the voltage would be low, consequently the Direct drive weak, and for a strong effect the voltage would be close to the nominal, and then we would have the maximum torque of the motor. This way all the setting of the interface would keep working normally, and we would be able to set up stronger or weaker effects.
    Does anyone think this idea can work? and have the hardware to test?
    Suggestions?
    Possible side effects?
    so far I believe this can work, my only concern is about the minimum voltage of the Driver, that maybe we would need to respect in order to avoid damage. test.png
  8. sikjar
    sikjar Xiao Nie
    Translator
    China
    818Coins
    I am not developing on this project any more, and I don't visit this forum very often, so most questions don't get any reply, sorry about that.
    As for your suggestion regarding about regulating the voltage, as far as I remember, the manual for the driver says that voltage only affects the motors speed (RPM), and not the torque.
    The torque is mainly influenced by the current (amperes) that the power supply can deliver.
    I tried hooking the driver up to a variable power supply, and it doesn't seem to make any difference to the torque whether it gets 24 volt or 80 volt.
  9. henrique fernandes
    melbourne vic
    188Coins
    You're right, controlling this voltage the torque doesn't change, I would need to control the current of the coil to change the torque.
    I don't know if there is anyone still interested in building something like this, but I will spend some minutes to share what I took hours find out.
    Basic fact - to control the torque we need to control the current(not the voltage as I thought).
    Following this thinking, I made a lot of research and I found that the most of the "Chinese cheap drivers" have current control by chopping the current. The problem then was that the mode of we set this current control is mostly through switches, so we couldn't control it by Arduino.
    Searching a bit more about chopper stepper drivers I found some circuits DIY based on the chip Toshiba tb6600, which can drive steppers using 10 to 42VDC up to 4.5A, and the mode of control of this circuit is via 10K pot, so the plan is to use one of this driver ( I found for 10 aud from China), and replace this pot by a X9C103 Digital potentiometer, so we can control it via Arduino
    PS: As the intention is to build the steering wheel not the driver I'll jump this part and buy one of this,(if someone is interested just let me know that I can share the project of this driver and some more information that I found about Chinese drivers, because I am convicted that we can use this "mod" in any driver)
    Cheap Driver Alternative.png I will copy the main idea of this post, use an Arduino to convert the PWM coming drom the DISCOVERY board into a percentage of torque( or percentage of Amps applied to the coils), controling this way the toque
    the direction signal I will use to set direction and a constant speed, sending pulses to the driver ( I'm not sure about using a constant speed, but it looks like this is the way the commercial FFB wheels work, constant speed and variable torque depending on the effect)
    I would like to listen to a second opinion about this crazy plan. Do you guys think this would work? any suggestion about the circuit or the mode of control?
  10. gefa
    gefa New Member
    Lithuania
    216Coins
    Hello, I am really interested in Your project, Did it succeed and is it working? I would really appreciate if You send an answer to my e. gefa96(etta)gmail,com
  11. henrique fernandes
    melbourne vic
    188Coins
    Hey mate. I'm still waiting for some stuff from China. I got my discovery board and made it work with my arduino. I'm using a Chinese clone of mega2560 and I made a program to read the pwm from the DISCO and depending on the duty circle control the digital potentiometer and send pulses to the driver to rotate the stepper.
    To proceed I need my stepper that is coming from China to test the current modulation but I believe it's gonna work
    On the next couple of weeks I may have more progress to post here
  12. Carlo_Labati
    Carlo_Labati New Member
    italy
    213Coins
    hy mate , did you know if exist or nothing "dead zone" ?
  13. sedesa tatasa
    sedesa tatasa Member
    503Coins
    Mmos have h-bridge mode.
    Two Photocouplers convert the signal to +-signal.
    And simple low pass filter make it +-analog signal.
    Photocoupler must be totem-pole output type.
    I use TLP2366.
    Low pass filter is configurated with two 1000Ω and 1uf.
    0%→90% 4ms
    About 1% min force is need at MMosForceFeedback2014.
    Maybe better two order low pass filter.500Ω×2 and 1uf×2.
    This is work well.but my motor is only 1.3 Nm max3.9 Nm(300%).
    I do not know if it works well with a big motor.
  14. Nonorfs
    Nonorfs New Member
    fre
    197Coins
    Hi all
    First of all, what an amazing project ! Great work.
    I start to make one.
    I earn all the most important part ( waiting for the case, fan, dc converter for fan, ... ).
    I have a problem with the encoder.
    I don't know how to plug it on the driver.
    I have some basics on electrical.
    My encoder is the Omron E6C2 CWZ6C
    I think that output A has to be plug with EA+ /// output B with EB+ ( Is that right ? )
    But how i can plug the Z output ??? on the leadshine HBS86H.
    This motor is the Nema 34, fix to my desk with an home made 3d print part.
    The encoder mount is also an home made 3d print part.
    Thx for your help.
    P_20180718_110518_vHDR_On.jpg P_20180718_105730_vHDR_On.jpg P_20180718_110528_vHDR_On.jpg P_20180718_110543_vHDR_On.jpg
  15. Pilgreem
    Pilgreem New Member
    327Coins
    • Old Old x 1
  16. Pilgreem
    Pilgreem New Member
    327Coins
    Here is some news.
    The casing is finish.
    The FFB is recognized by all cars game ( pcars2 , dirt 4 , ... )
    It can turn wheels when ffb is off.
    I have some trouble when ffb is ON.
    I think i found the problem and try to solve it as fast as possible.
    Just for information when the ffb is ON, it will be very hard to turn it by hand ( i think ffb is at max due to bad wiring of my encoder ), maybe at 13Nm ( the max of the stepper motor ).
    I left another feedback asap.
  17. danove_b
    danove_b Active Member
    Sweden
    1,782Coins
    Kind of interested of how you guys have succeeded with your projects. Have any of you considered trying to find the PWM signal inside driver (HBS86H) that controlling the current flow/torque? Shouldn't be that that hard to find by follow backwards from the MOSFET drivers using a oscilloscope. Hopefully there is a common PWM for both winding that are gated with other outputs from the CPU. If so, you could replace the signal directly with the PWM signal from the MMOS. (Running the MMOS in PMW/Dir setup)
  18. Lebois
    Math teacher
    2,565Coins
    I guess this is the way RufusDufus gone in "Son of OpenSimwheel", but it's quite hard and risky...
    An other solution is to try IonI Pro driver that is compatible with Stepper motors. It costs around 350€...
    I am waiting for the RJ45 cable and will try Sikjar solution with my Nema 34 and ACT-motor HBS86h driver.
  19. danove_b
    Sweden
    1,782Coins
  20. Ultrawipf
    Ultrawipf New Member
    123Coins
    @Pilgreem @Nonorfs
    Sorry for the reply in the old thread but this is very relevant to me.
    I also took a look at the HBS86H for a new ffb project but as mentioned the drive force for small position errors must be reduced for steppers to act like servos.
    This driver has a serial port and a software to configure it.
    From the manual it seems that you can decrease the error gain and drive strength and also increase the alarm tolerance to position errors.
    Could someone with this driver try the software configuration and report if this is a valid way to control the drive strength depending on the position error?
