SCN5 / SCN6 Hardware Thread
Discussion in 'SimTools compatible interfaces' started by egoexpress, Sep 29, 2008.
Thread Status:
Not open for further replies.
  1. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    Re: SCN5 Hardware Thread
    Anyone know how to identify and where to buy the two small wire plugs on the inside of the SCN5 plastic cover?
  2. dre99gsx
    dre99gsx New Member
    0Coins
    Just to confirm:
    This USB->RS485 adapter plugs in and worked immediately:
    <a class=postlink href=http://www.trossenrobotics.com/store/p/5889-USB-to-RS485-Connector.aspx onclick=window.open(this.href);
    return false;>http://www.trossenrobotics.com/store/p/ ... ector.aspx</a>
    <a class=postlink href=http://www.robot-electronics.co.uk/htm/usb_rs485_tech.htm onclick=window.open(this.href);
    return false;>http://www.robot-electronics.co.uk/htm/ ... 5_tech.htm</a>
    No setting changes needed (yet) from the interface setup menu (SCN5 motor setup menu). I was able to move my 150mm SCN5 from 1% to 100% and in between.
  3. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    Hi guys,
    I've read the whole thread, but two questions concerning mounting the SCN5 on my rig are left:
    1.) I guess, I have to mount the 100mm SCN5's lift rod half way out resp. in the middle position (50mm). Should I pull the lift rod out by hand to the preferred position or is there any possibility to get this done by the electronic or by Software ? I don't want to damage anything...
    2.) I plan to use a killswitch as recommended here in the thread and in the Wiki. Does an usual switchable connection strip do the same job (only for killing the power in case of system hang-up it should do) ? Anywhere in this thread I have read that I have to take one of the cables to place the killswitch there... please give me some hint, where the switch should be mounted.
    Thanks in advance and bye,
    Chris
  4. bvillersjr
    Ohio, USA
    437Coins
    Once you have the actuators connected properly, X-Sim will initiate their calibration, which result in them landing in the centered position.
    [/quote][/quote]
    The switch should be mounted where you can reach it while driving. I do not know what you mean by a switchable connection strip so I cannot comment on that question.
  5. dre99gsx
    dre99gsx New Member
    0Coins
    You could always have a powerstrip dedicated to the 24v SCN5 Supply and just flip the switch it in an emergency (I assume that is what he meant).
  6. XRiccardo
    XRiccardo New Member
    1Coins
    :sos:
    you could tell me the codes of contacts? the plastic is: H3756-ND and A25571-ND in DIGI-KEY site but contacts? I can not understand what they are.
    Thank you.
  7. bvillersjr
    Ohio, USA
    437Coins
    I would prefer connecting them internally buy connecting the smaller plugs shown above. The number on the plugs are as follows.:
    Larger 14-pin Plug # - H JST 14
    Smaller 4-Pin Plug # - HJST II 4
    Anyone have any ideas where I can buy these?
  8. Schnullerbacke
    Germany near Munich
    369Coins
    Bernard, when I talked about a connection strip with a built in switch, I meant something like that:
    http://upload.wikimedia.org/wikipedia/commons/1/1d/German_power_strip.JPG
    I will plug the two SCN5 to the strip, place it near to me and can switch off the SCN5-power if the system hangs up. I think, it's the same like a real killswitch - but cheaper ;-)
    Thanks,
    Chris
  9. XRiccardo
    1Coins
    Look here http://www.jst-mfg.com/c00sea/SearchIchiran00_e.html
    :hi:
  10. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I've picked up my pair of SCN5 100mm today :yippiee:
    Just had to pay 19% EuSt = 95,81Euro. Mirai marked the correct Taric code on the parcel and saved me a lot of explanations this time :thbup:
    Regards
    Christian
  11. Schnullerbacke
    Germany near Munich
    369Coins
    Congrats, Christian :clap: !
    Yeah, it's a beautiful piece of High-Tech !
    I'd rather live in your country, because it seems that the clerks in Frankfurt don't want to have such long discussions like here in Augsburg...
    Anyway - have fun with mounting them... I hope that I will have enough free time this weekend for my SCN5 :yes: !
    BYe, Chris
  12. Michael N.
    Michael N. Member
    Germany, NRW, Düren
    611Coins
    :clap: :thbup: . Hope to see a Video soon from your updated Simulator :)
  13. nicky
    nicky New Member
    0Coins
    Congratulations.
    The mine arrived Saturday, it was faster for France. 8)
    I paid 36 euro fee :yes: ($ 100 bill for two? ... thank Mirai ! :thbup: )
    Now it's time to build it..
  14. egoexpress
    421Coins
    You lucky one :thbup:
    They wanted to see my paypal bill...
    The german customs officers dont let us cheating on them that easy :lol:
    However, it was not the first time I have picked up SCN5 there, and they seem to have had some more SCN5 going through their office the last few weeks, so they should know their value quite well now...
    Regards
  15. dre99gsx
    dre99gsx New Member
    0Coins
    You don't know what your missing. I got a stiff neck from the SCN5s. All the movement you need! :eek:
  16. nicky
    nicky New Member
    0Coins
    He asked me an invoice. :mug1:
    Mirai kindly sent me one in less than an hour to the price of the package!
    Mirai are very responsive and sympathetic! :clap:
  17. nicky
    nicky New Member
    0Coins
    I buy two of this adapter.
    They work fine!
    Cheap price and good product!
  18. XRiccardo
    1Coins
    there is a limit to the number of SCN5 actuators that can I use?
    Can I connect 4 SCN5 actuators, 2 for axis x and 2 for the y axis?
    Thanks!
  19. egoexpress
    421Coins
    Yes, you can use multiple actuators. In your case, just assign 2 actuators as axis 0 and 2 as axis 1,
    That way you can move a co-pilot seat syncroneous.
    regards
  20. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Great Sirnoname!
    :cheers:
    I guess Bvillersjr will be very happy! ;)
Thread Status:
