Help with RacingMat Code for 2DOF Hbridge
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by zylle, Oct 22, 2016.
  1. zylle
    zylle New Member
    Denmark
    124Coins
    Hi everyone! :)
    I've been building my 2DOF simulators frame this weekend and mounted my motors and such, as I'm currently waiting for my arduino and hbridge to arrive in the mail. I came across RacingMats code for arduino that can be used with a H bridge and looked into it, as i would like to have everything ready for when my electronics arrive, and couldnt figure out how i should wire my h bridge up to the arduino. As seen in the code here, it looks like that i should wire 2 directions up for each motor?
    But my hbridge only supports on direction pin for each motor connectec ( as seen in this picture)
    Sorry if its a bit of a noobish question, but i would hate to come home to my new h-bridge and arduino and be stuck on this for hours :p
    Thanks a lot in advance for the help, my build will have its own thread when i get some pictures of the frame :D
  2. zylle
    zylle New Member
    Denmark
    124Coins
    Alternatively, are there any useful arduino codes that i can use with my h-bridge that i bought?
    Thanks a lot in advance! :)
    152,718Coins
    +11,092 / 56 / -2
    A model number and specification link would be far more helpful than a hbridge picture.
  4. zylle
    zylle New Member
    Denmark
    124Coins
  5. evolaco
    evolaco Member
    Spain
    694Coins
    Hello, have you managed to run that h-bridge with some arduino code and simtools? Looks very robust and with a good cooler I think it could be 30a and over 60a max
  6. Vladimir
    Vladimir New Member Gold Contributor
    Russia
    288Coins
    This H-bridge with firmware must be connected in this way:
    7 pin - DIR1; 4 pin - DIR2; 5 pin - PWM1; 6 pin - PWM2;
    8, 9 pin - not used.
  7. evolaco
    evolaco Member
    Spain
    694Coins
    Smc3?
  8. Vladimir
    Russia
    288Coins
    For Smc3 connection: 2 pin - DIR1; 4 pin - DIR2; 9 pin - PWM1; 10 pin - PWM2.
  9. evolaco
    evolaco Member
    Spain
    694Coins
    Thank you very much for replying, those connections would be in mode 1 of smc3? No need to change anything
  10. Vladimir
    Russia
    288Coins
    Yes, all connections for mode1, pin 3 and 5 are not used.
  11. evolaco
    evolaco Member
    Spain
    694Coins
    Thank you very much, my friend, this bridge with a good heatsink could end up much more than the 10A (30A peak) that says in its characteristics?
