SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. SilentChill
    20,400Coins
    SilentChill submitted a new resource:
    EliteDangerous Horizons Plugin (VR Version) - EliteDangerous Horizons Plugin (VR Version)
    • Like Like x 5
  2. Bubba Gump
    Bubba Gump New Member Gold Contributor
    USA
    60Coins
    I'm new here. Thanks for uploading this. However, I'm getting no motion and no numbers in the tuning center. It may be the wow64ext.dll error that I've been unable to resolve. I'm running SimTools pro 2.1 on a Win10 machine. The setup is working with War Thunder and Project Cars, just not with Elite Dangerous.
  3. SilentChill
    20,400Coins
    Only thing I can suggest is to make sure wow64ext.dll is in your simtools install folder and make sure you are running all the simtools programs as Administrator. Hopefully that works
  4. Bubba Gump
    USA
    60Coins
    Thank you. I saw that in another thread and have been doing that. It seems to only be an issue with Elite Dangerous. The Game Manager does manage to recognize that the game is running, giving me the blue bar, so I assume that there's some small thing that I overlooked.
  5. SilentChill
    20,400Coins
    There is also GetBaseAddress64.dll I forgot about that, I presume you have moved that into the simtools dir ?
  6. Bubba Gump
    USA
    60Coins
    GetBaseAddress64.dll seems to have done the trick. I still get the wow64ext error, but values register in the tuning center now, and the chair is moving. Thank you for your help.
  7. George Dobransky
    Hungary
    - 19Coins
    Great job, Craig4
    It's working in Vr, but i still have random movements in SC, dropping from SC, and in hyperjumps also.
    Cheers,
    George
  8. George Dobransky
    Hungary
    - 19Coins
    And if I'm in SRV and the spaceship leaves, also get some movements...
  9. Bubba Gump
    USA
    60Coins
    Are the max/min values the same as they were for the other version (+/-1.8 for roll and +/- 1.1 for the rest)? This setup is bucking me around in supercruise enough that I feel like I actually need to install the seatbelts.
  10. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Credo perchè hai comprato la licenza per il software, mentre i plugin sono "patrimonio" della community e vengono resi disponibili solo per chi partecipa attivamente alle discussioni.
    Per avere accesso ai plugin si può comperare l'accesso con appositi pacchetti...
    I think because you've purchased the software license while the plugins are community assets and are made available only to those who are actively participating in the discussions. To have access to the plugins, you can buy access with special packages ...
    https://www.xsimulator.net/community/account/upgrades
  11. Bubba Gump
    USA
    60Coins
    I figured out that the bucking issue was related to the levels in the profile editor. They were set at the maximum values (from some debug session earlier). Once I dialed them back down close to the default levels, the ride got a lot smoother.
  12. SilentChill
    20,400Coins
  13. SilentChill
    20,400Coins
  14. value1
    14,498Coins
  15. Bubba Gump
    USA
    60Coins
    No luck for me. I still get the wow64 error on patch and have no motion from the chair with Elite Dangerous in VR. I did verify the War Thunder works okay, and that GetBaseAddress64 was in the SimTools directory. Perhaps my Tuning Center values are incorrect? They are 1.78/1/0.8/1/1.2/1.95 (I don't remember setting those.)
  16. value1
    14,498Coins
    You MUST run GameManager in admin mode when patching!
  17. Bubba Gump
    USA
    60Coins
    I thought that I had, but to double check I un-patched the game -> shut down all SimTools programs -> used the plugin updater to re-apply the plugin -> restarted GameEngine and GameManager in admin mode -> re-applied the patch in GameManager (again getting the wow64 error) -> hopped in game to check it out. Since I was still getting no chair motion, I opened the Tuning Center and restarted the game. The Tuning Center is showing no game data output. I'm running version 2.3.10 of Elite Dangerous with an Oculus Rift. The plugin DLL reports that it is version 2.0.0.2.
  18. value1
    14,498Coins
    What does "the wow64 error" say?
    And can you try to copy the wow64ext.dll manually to the installation directory of SimTools?
    The wow64ext.dll is contained in the EliteDangerous64_GamePlugin.zip
  19. Bubba Gump
    USA
    60Coins
    "Error while trying to install wow64ext.dll. Please run Game Manager in Admin
    mode or
    copy the file 'wow64ext.dll' (contained in the plugin zipfile)
    manually to the installation directory of SimTools!"
  20. value1
    14,498Coins
    Thx. Does it work when you copy the file 'wow64ext.dll' manually to the installation directory of SimTools?
Thread Status:
