SCN6 - moving with hand?
Discussion in 'Commercial Simulators and Peripherie' started by Martyn, May 18, 2017.
  1. Martyn
    Martyn Member Gold Contributor
    Europe
    49Coins
    2DOF, SCN6
    Today i´ve noticed that one of mine shoulder mounted Frex´s SCN6 (150mm / 20kg) does not hold the seat when i sit on it when everything turned off:(
    It moves back.. I can even move it with the hand. The second one hold himself properly. It also seems that the "moving" one is little slower that second one:(
    Is that normal or should i begin to worry?:(
  2. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    My 5's do the same when powered off so no need to worry ;)
  3. Martyn
    Europe
    49Coins
    2DOF, SCN6
    Well it just freaks me out, because it do only one acurator, and some time ago it did not do at all..
  4. GTHQ_koop
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    I been using it for almost 2 years now and bought it from a guy who used it for 4 so I would stop worrying..
  5. Martyn
    Europe
    49Coins
    2DOF, SCN6
    Well one of thouse does not sound so healthy now:(
    Was used for tracktion loss..
  6. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 72Coins
    the worm drive is worn and your stepper motor is also had enough... the sound your hearing could be the little pin in the very top of the shaft.. Here at simworx we strip and rebuild brand new scn5 -6 we drill and tap the hole where the pin was and screw a bolt into it..the whole shaft can pull out if the pin is worn.. id be ordering a back up..
