DIY Pedals & Buttons Controller
Discussion in 'DIY peripherals' started by TOPMO3, Jul 30, 2016.
  1. TOPMO3
    TOPMO3 Active Member
    Russia
    896Coins
    Hi @razzor13bt
    you should use 3.3V
    Did you solve the problem with reassigning buttons in AC?
  2. razzor13bt
    razzor13bt Member
    automotive technician, sales manager.
    Durban, South Africa
    393Coins
    thanks for the quick reply.
    i havent had a chance to check.
    Am hooking up the pedals, button box and the sequential shifter.
    then only the wheel will be indepentant of the stm.
    once hooked up i need to get familiar with your app and program everything.
    hope to have sorted by end of the week.
    once again thank you.
  3. TOPMO3
    Russia
    896Coins
    OK
    feel free to ask any question about the app. Its my first PC app for 20 years after univercity, so its may be not so intuitive and user-friendly ))
  4. ferslash
    ferslash Active Member
    4,798Coins
    man, sily question...
    can i take your project and use it on an arduino board, or the code sketch works only on the st board?
    best regards
  5. TOPMO3
    Russia
    896Coins
    @ferslash sorry, it only works on stm32 board
  6. Giustino
    Giustino New Member
    247Coins
    Hi TOPMO3
    can you reshare your links, these are offline.
  7. TOPMO3
    Russia
    896Coins
    Hi all
    here is new version of the firmware and app.
    Added support for 1/2 and 1/4 step encoders and ability to connect encoders in single (non chained configuration).
    Project URL
  8. Giustino
    Giustino New Member
    247Coins
    Awesome work Top! Maybe I'll be the first to check new firmware. I am still waiting the material. I'll update you as soon as possible.
  9. Giustino
    Giustino New Member
    247Coins
    @TOPMO3 How do I connect one hat switch to your schematic? is it compatible with your firmware?
    I'm thinking that in AC it is necessary to set the pit strategy.
  10. TOPMO3
    Russia
    896Coins
    Hi @Giustino
    Yes, you can connect Hat Switch. From hardware side of view POV switch is just 4 buttons, so you can basically use any 4 buttons for it. If AC allows remap buttons, you can remap these 4 buttons for functions you need. If AC requires POV Switch defined in USB descriptor, so you can configure your 4 buttons to act as POV Switch in the Buttons tab
  11. RacingMat
    21,052Coins
  12. Giustino
    Giustino New Member
    247Coins
    Is there anyone who can suggest a hat switch / pov and where to buy it? Obviously of acceptable size for a steering wheel. I found something like as a ps2 joystick but It is too big.
  13. TOPMO3
    Russia
    896Coins
    Hi all
    Here is 0.12 version of OSH PB Controller. Please make full chip erase before uploading the new firmware.
    app now shows both OSH Studio and firmware version. They should be equal.
    Added Tuning Tab. It allows:
    - define unique identifier for the device. It will appear in brackets after main product string
    - define different serial number for defferent devices. If you have several controllers, they should have different s/n to help windows identifing them.
    - change USB polling interval. Default value in 16ms is enough for button boxes or rim plates, but if you building high performance pedals (for example) you can consider to decrease it up to 1ms.
    other parameters I think are self explaining. "Amount of time a button will be pressed" is how long virtual button appears to be pressed in windows. Debounce time you can increase if you notice some transient presses.
  14. Nick Moxley
    just got my boards today, Ill get to playing with them asap. :thumbs:thumbs
  15. Ned
    Ned Member
    fixed operations manager
    melbourne
    714Coins
    That Is cool
  16. CorradoSKJ
    CorradoSKJ New Member
    Poland
    Poland/Bydgoszcz
    693Coins
    2DOF, Arduino, Motion platform, 4DOF
    Hi, amazing work.
    I have small problem, I need 4 analog axis and i make this in OSH Studio but first 3 axis Assetto recognize but 4 not. In OSH Studio all 4 axis works perfect. What i doing wrong ?
  17. TOPMO3
    Russia
    896Coins
    Hi @CorradoSKJ
    Currently 4, 5 and 6 axises made as Vbr* (USB HID standart has several meanings for axises, but usually a game allows to map any axis to user function)
    Is it inly AC issue, did you try any other game?
    I can made those axises as sliders for example, just for try
  18. CorradoSKJ
    Poland
    Poland/Bydgoszcz
    693Coins
    Yes i try Dirt Rally, Assetto and Project Cars. I use Your v0.12 firmware and latest OSH Studio, in control panel i see only 3 axis, in AC i see 8 axis but works only 4, 5 and 6 in OSH Studio i see 6 axis but works first 4.
  19. TOPMO3
    Russia
    896Coins
    Sorry, now I'm confused a little bit
    What is correct?
    "first 3 axis Assetto recognize but 4 not."
    or
    "in AC i see 8 axis but works only 4, 5 and 6 "
  20. CorradoSKJ
    Poland
    Poland/Bydgoszcz
    693Coins
    Sorry my bad in AC i see 8 axis but works only 4, 5 and 6
