Game Dash crashing??? windows error sound repeating, not output to gauges
Discussion in 'SimTools Pro & Entertainment Version' started by minimus1899, Mar 20, 2017.
  1. minimus1899
    minimus1899 Member
    retired/broken/falling to bit
    lincoln
    163Coins
    hi all im new to the forum and purchased the pro version of the software after following dahfl's post of the BMW e36 dash tacho and i did everything to it correctly but.... and its a big but. the every time i load up LFS it goes mad and i get the windows error sound over and over and over again till i close game dash, HELP?????
    meny thanks
    andy
    153,914Coins
    +11,154 / 57 / -2
    Can you please post pictures of all of your settings and likely a video would also help.
  3. minimus1899
    minimus1899 Member
    lincoln
    163Coins
    hi all sorry for late reply i recorded the probelm hope it help
  4. yobuddy
    51,537Coins
    The problem is in Dash1, you have a Math *3.6 instead of Math * 3.6.
    Looks like you forgot a space?
  5. minimus1899
    minimus1899 Member
    lincoln
    163Coins
    ill have to try it out tomorrow as ive had dialysis today and its worn me out, off the scrap yard tomorrow morning for some parts for the sim, as the old bmw e36 cluster failed on me...... the air cores went do lally and made them floppy, i have how ever had it working on the laptop tonight, so tomorrow ill boot up pc and see whats what,
    thanks again
    andy
  6. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    hey mate im having the same issue in iracing
  7. Evan Rowlands
    Melbourne Australia
    - 82Coins
    here is a video of my settings its beeping the same and the data is frozen
  8. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    you have wrong configuration for MATH it's a * not a ''
  9. Evan Rowlands
    Melbourne Australia
    - 82Coins
    thanks mate one thing i just noticed is there is water temp on dash 8 i read that you have to change it to dash 13 i looked though the script but i couldnt find anything that looked like it... ive no idea what im looking for btw lol
  10. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    @Evan Rowlands have long time to use game dash but i think you don't have to change anything in the script only in game dash interface settings you have to mach the letter from the script(.ino) file to the dash output you get values IE if the letter for temp is C and you get values from dash 13 interface for temp would be C<Dash13>
  11. Evan Rowlands
    Melbourne Australia
    - 82Coins
    ok so the beeping has stopped thanks mate now i have this screen up but nothing changes.. sim dash is outputing but nothings changing on the screen here are so pics
  12. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  13. Evan Rowlands
    Melbourne Australia
    - 82Coins
    yeah ive done that
  14. Evan Rowlands
    Melbourne Australia
    - 82Coins
    i just checked and the water is set for dash 13 but it outputing on 8
  15. minimus1899
    minimus1899 Member
    lincoln
    163Coins
    i had to reinstall windows to make mine work wasnt a big deal as got a bigger hdd anyway but with havnt needle jumps on my other tread
  16. Evan Rowlands
    Melbourne Australia
    - 82Coins
    yeah ok i dont want to be doing that..
    the beeping stopped and i have all thew info on screen sim dash is outputing but nothing moves on the dash
  17. Evan Rowlands
    Melbourne Australia
    - 82Coins
    cheers mate that fixed the beeping
  18. yobuddy
    51,537Coins
    Game Dash will "Beep" when it tries to process a bad command. {letting you know something went wrong)
    btw, you can add edit commands while the game is being played.
  19. Evan Rowlands
    Melbourne Australia
    - 82Coins
    yeah i fixed the beeping issue i had " instead of * beeping stopped striaght away when i changed that...when you say edit commands what do you mean brother.. ive tried 3 diffrent boards ive played the bits per second if i have it on 57600 i have all info on screen but its frozen if i go up to the 115200 theres numbers all over the place but they change and as i drive more info pops up same if i go higher with the bits if i go under 57600 nothing comes on screen but once on track bit by bit things pop up all in the wrong placse and wrong valve to sim dash my interface output is set to 1ms ive gone up to 30 but nothing changed im looking to do a course on arduino to make this easier for me ive spent 2 days on this now
  20. yobuddy
    51,537Coins
    You need to make sure that the bits per second of the outgoing interface matches the bits per second of the arduino its connecting to.
    You should be able to peek in the sketch for the ard to see what speed it wants to communicate at.
