UK 6 DOF AC Motion Build
Discussion in 'DIY Motion Simulator Projects' started by paulg100, Feb 12, 2017.
  1. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
    are you sure thats not the wrong way around speedy? draw on the three phase side is less than the single phase side not more.
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,941Coins
  3. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    excellent job, but out of curiosity what it cost to build this type of platform?
  4. paulg100
    Bristol UK
    1,373Coins
    Thanks, basic parts for wormgear lever type platform 4-5k, then however much more you want to spend.
    Or you could go servo motor route with no need for VFD's, would be more.
    Or you could go AC motor/Servo motor custom linear actuator route.
    DC linear actuator route is much cheaper and I would think just as good or possibly even better for VR racing, if that solution was known before I started this build I would have likely gone that route first. However if you want larger range of movement maybe for flight or to mount a full cockpit with more weight or don't want to use VR (why wouldn't you its awesome!) then maybe AC is better.
    I don't have a DC rig to compare, at least not at the moment ;)
  5. paulg100
    Bristol UK
    1,373Coins
    Good info in the link speedy, all I know is my sim is less than 40 amps as it never trips, but for someone starting a build that would be very useful for calculation.
    when I was buying cable, switches etc I just though take 3phase draw eg 5 amps and multiply by 3 for single phase side, that should cover it :)
    The manual advised 30amp fuse for my vfd but they must have a large safety margin for stall.
    Again putting each VFD on its own MCB just makes it really easy for isolation but definitely not necessary as you say.
  6. paulg100
    Bristol UK
    1,373Coins
    The wheel button plates from the great design in this thingy don't fit my wheel:
    http://www.thingiverse.com/thing:1678086
    So started to make a custom one
    hoping to include a thumb stick if the blue UHID supports it, so I can control the mouse cursor for assetto corsa menus
  7. That Dude There
    That Dude There Member
    USA
    430Coins
    The printer comes in handy. Let us know how it turns out.
  8. SilentChill
    20,582Coins
    Hi matey have you a link to the thumbstick ?
  9. paulg100
    Bristol UK
    1,373Coins
  10. SilentChill
    20,582Coins
    Thanks and sorry I was really really lazy there, I could of searched lol
    Good idea though as using mouse in AC is a pain the arse and I forget about it all the time it goes flying off the rig, mines smashed and been superglued too many times
  11. paulg100
    Bristol UK
    1,373Coins
    lol NP, yep i use a small wireless HTPC keyboard with a track pad, I have a strip of hook and loop velcro on the back and a bit on my platform so the keyboard just stays put but its still a pain in arse having to scramble for it everytime i want to restart a session etc so thought the thumbstick would be a very handy option.
  12. Nick Moxley
    17,056Coins
    Ctrl+O is your friend.
    MENU:
    F11:
    toggle fullscreen/windowed
    IN-GAME:
    CTRL+R :
    replay
    CTRL+S : slow motion (replay)
    CTRL+A : ABS on/off
    CTRL+T : cycle traction control modes
    CTRL+H : show/hide apps
    CTRL+O : restart session
    CTRL+L : disable names
    CTRL+M : toggle mouse steering
    CTRL+G : gearbox Auto
    CTRL+I : racing line on/off
    CTRL+Q : damage displayer on/off
    CTRL+J : show damage displayer
    1 .. 0 : Turbo boost management
    CTRL+1 / 3 : MGU modes
    VR (OCULUS):
    CTRL+Space:
    recenter view
    Look Left+Look Right: recenter view
    F1 : cycle car cameras
    F2 : random cameras
    F3 : track cameras
    F5 : pivot camera around the car
    F6 : cycle on-board cameras
    F8 : in-game screenshot
    F9 : toggle bottom learderboard
    F11 : toggle virtual mirror
    F12 : (Steam related) screenshot
    KeyPad +/- : Change Force Feedback (disabled in replays)
    Ctrl +/- : Change onboard FOV
    Ctrl Shift +/- : Change saturation
    PageUp/Down : adjust exposure
    Home : Open/close console
    MULTIPLAYER:
    CTRL+NUMPAD_1:
    switch to previous opponent car
    CTRL+NUMPAD_3: switch to next opponent car
    CTRL+NUMPAD_2: switch to player car
    CTRL+L: toggle opponents name
    SERVER ADMIN:
    /help:
    prints the list of the available commands
    /admin: become administrator for the server. ex, if the password is "kunos" the command is "/admin kunos"
    /next_session: moves to next session
    /restart_session: restart the session
    /kick: kick a user using the rules (blacklist etc) of the server. To kick a player named "The Player": /kick The Player
    /client_list:
    show the player list by CAR_ID: name
    /kick_id: kick
    a user using the rules (blacklist etc) of the server. To kick a player using the CAR_ID 2: /kick_id 2
    /ban_id: ban
    a user using the rules (blacklist etc) of the server. To kick a player using the CAR_ID 2: /ban_id 2
    /ballast:
    add ballast (Kg) on the CAR_ID. To add 100Kg to CAR_ID 2: /ballast 2 100
    SHOWROOM:
    ENTER
    : enter/exit the car
    SPACE : open/close doors
    NUMPAD_7 : lights on
    NUMPAD_8 : stop lights on
    NUMPAD_0 : animate wing 0 (if present)
    NUMPAD_1 : animate wing 1 (if present)
    NUMPAD_2 : animate wing 2 (if present)
    NUMPAD_3 : animate wing 3 (if present)
    W : wiper
    I : car gearbox animation
    right mouse button: move the car
    , and . : rotate wheels/ steer
    F7 : FPS mode
    TAB : track camera
    pag up : previous skin
    pag down : next skin
    + / - : adjust FoV
    F : roll left
    G : roll right
    Q : Azimuth +
    E : Azimuth -
    A : Zenith +
    D : Zenith -
    • Useful Useful x 3
  13. paulg100
    Bristol UK
    1,373Coins
    Thanks Nick thats really helpful,
    Erm i think i might need a few more buttons on my wheel :)
    I didnt notice an option in the blue UHID to send a string, only a single key stroke,
    if we could send ie:
    /restart_session
    EDIT: Or CTRL+O
    with a button press that would be really handy, could probably do it through joy to key if not through uhid config tool.
  14. paulg100
    Bristol UK
    1,373Coins
    OK read the uhid manual a bit more, you can programme multiple key presses through the macros.
    Ive ordered a thumbstick now so will still probably incorporate that on my wheel but some of those keyboard shortcuts programmed to buttons
    will make life so much easier, thanks again for the heads up Nick.
    Still don't understand why they couldn't add menus navigation through the arrow keys or something but no matter.
  15. Nick Moxley
    17,056Coins
    Make sure to let us know how you make out.
