Question 2dof problem with arduino/motomonster
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by marko, Mar 2, 2017.
  1. marko
    marko New Member
    finland
    146Coins
    any help this problem i have.. using windshield wipers and arduino/motomonster
    just got my rig "working" but the problem is when motors go just a little down at the midlepoint they get stuck. i have to manually move the motors up and they stops at the midlepoint. up they work fine put down it stuck's
    im using racingmat code
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    wiper motors may have an internal stop position where that is related to the actual lowest point of the wipers on the car front shield ... make sure you eliminate those position contacts and have a continuous connection to the motors that makes them rotates endless ...
  3. marko
    marko New Member
    finland
    146Coins
    i think we got it.. we may have some motor ground issues.
  4. RacingMat
    21,059Coins
    please post some pictures of the motors :)
    and yes, it's mandatory to check (and remove) motor case grounding!
  5. marko
    marko New Member
    finland
    146Coins
    yeah we did that..still wont work. it tilts forward and back to center but when we tilt it all the way back it stuck's there and it wont tilt back to center
    i dont have better pic now :(
  6. speedy
    Alexandria , Egypt
    7,944Coins
    just remove that cover and you'll see what I mean ...
    BTW ... those motors could cause a short circuit to the metal chassis as you use +ve and -ve to their body when forward and reverse the direction ... use proper insulation from the chassis .
  7. marko
    marko New Member
    finland
    146Coins
    done all that..this is how it's now. no short circuits..all wiring is ok.. when it tilts back it doesn't go all the way pot's max limit when it stuck's
  8. marko
    marko New Member
    finland
    146Coins
    so i tested it now and when it comes back forward position to center it goes maybe little over it and stuck's..then i pull it manually back to center(about 1cm) it moves again when i give arduino command, but only forward and center and same again...in center position when i give command to tilt back it goes about half of center and pot's maxlimit.
  9. speedy
    Alexandria , Egypt
    7,944Coins
    This is not a problem description my friend ... this is the easy way for getting lost description :) ... please speak with your native language and provide the best google translation as much as you can ...
    Some of our multi language members here will sure catch what you need .
    Answer these questions please as much as you can :
    • Are you using the SMC3 code for the Arduino ? If yes -> post a screenshot for that motor settings .
    • Is the error in two motors or just one ? If yes -> test the other motor for the same MM .
    • Have you test replaced the pot of the other motor ?
    Good luck .:thumbs
  10. Pit
    30,498Coins
    Obviously he is using the racingmat code
  11. Tim McGuire
    Canada
    2,223Coins
    3DOF, DC motor
    What's your PWM Max duty cycle setting at? Not many people have this problem, but sometimes on my rig, if I get a large current spike, the overcurrent protection on the monstermoto will trip out and the motor will "die" (it will cut power). The motor driver won't wake up again until the motor has been manually rotated back into place for the position set point (this is probably a safety thing in the driver chip, it won't unlock until the output duty cycle drops back to zero again).
    If the grounding issues aren't at fault, then try lowering the max duty cycle to between 80 and 90% and see what happens. Then just keep raising it until you reach whatever the threshold is before the problem starts to arise again.
  12. marko
    marko New Member
    finland
    146Coins
    problem solved! for some reason potmini cant be under 450o_O
