T500RS custom GT wheel mod + Optional parts
Discussion in 'DIY peripherals' started by f1simgames, Oct 26, 2015.
  1. f1simgames
    f1simgames Member
    516Coins
    Hello all,
    i start modding my original T500RS GT wheel to an update GT Wheel version with lcd display , rgb led rpm indicator and more push buttons.I use MAX7219 for display and WS2812b for RPM.So let's start,
    THE WHEEL
    After that , i think to create a button box for more data that is not so important to be in wheel.As i mod the button box i decide to use another one TM1638 lcd for show there the "secondary" informations.
    THE BUTTON BOX
    And then...i think to make an external Gear Indicator....cutting....drilling...carbon vinyl wrap..and...
    THE GEAR INDICATOR
    So the project was ready to test....let's go...
    I hope you like it...
    Thank you for reading....Thomas.
    • Like Like x 10
  2. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Nice job!
  3. f1simgames
    f1simgames Member
    516Coins
    Thank you Hobbs!
  4. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Very good job !! I love it
    I will draw inspiration from your work to change my G27 :thumbs
  5. f1simgames
    f1simgames Member
    516Coins
    Thank you Leaedman....of course you can use my design to your G27....waiting for results!
  6. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    Beautiful, i would like the same for the wheel.
    Is it possible to have more information please ?
  7. f1simgames
    f1simgames Member
    516Coins
    Thank you Foehn,ask me anything you want to know.
  8. f1simgames
    f1simgames Member
    516Coins
    So .... new update on PanelBox with a totaly new design!...Hope you like it!
  9. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    Can i ask what you use to drive big 8 segment indicator i made mine and the light is barely visible.
  10. f1simgames
    f1simgames Member
    516Coins
    What display do you use?....must be high brightness display first and second how do you powered the display?...
    i use high bright display and i powered it with a USB cable from PC USB port directly to power connectors of the display.
  11. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    I like it, sure.
    Where did you found the stickers/texts for naming the functions and level black yellow and red ?
    tks
  12. Cvetan Cvetanov
    Teteven Bulgaria
    1,462Coins
    i use arduino but current they want is more than 40 ma and i need driver for this to be able to provide them more current.
  13. f1simgames
    f1simgames Member
    516Coins
    All stickers is created by me Foehn....i print it in vynil sticker paper with laser color-graphite printing.
  14. f1simgames
    f1simgames Member
    516Coins
    You can powered the gear indicator with USB Cable directly from PC USB port.I use a simple use cable,cut the end and i solder + and - cables to a male-female adapter and i powered the gear indicator.
  15. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    It's a good idea, I will try to do the same. Thanks
  16. f1simgames
    f1simgames Member
    516Coins
    X-MAS Gift from F1Simgames.....here is my stickers file for my PanelBox....It is in EPS format and you can printing.Also file have cutting lines so,you can print it and cut it to a professional typing printer.
    Please don't edit my file and if you want use my F1Simgames logo (included in file) to your projects.
    Thank you guys!....;)
    Download link : https://mega.nz/#!1tpnEJDD!oGU6c8MczWs32U0NL-Nh2YC9SCZcy5mfRSJHemvNils
  17. zigzag49
    zigzag49 Active Member
    706Coins
    Very good work, your project is a source of inspiration.
  18. f1simgames
    f1simgames Member
    516Coins
    Hello again guys,
    i just finished 2 new mods.
    TM 599XX EVO 30 Alcantara wheel mod.
    Wheel have 10 push buttons with button guard , magnet shifter paddles and custom center logo.
    T500 RS Original GT wheel mod
    Wheel have 13 push buttons (Original and custom) and will install magnet shifters paddles too.
    Also you can see SimDisplay.Working with 2 X LCD Digital displays for Simulator data and 1 X RGB led strip for RPM indicator.
    Hope you like them!
  19. ouarlux
    ouarlux New Member
    france
    239Coins
    hello
    nice project :)
    i ve a question about your dash, how do you fix it on the t500 base ? behind the soft part ? how you can see it into the whell ??? i ve a ferrari GT and i cant see the dash into it , and when i turn it ,the 2 levers hit the dash.
    fot ur plate on the dash you use plexi ans vinyl or real carbon because look very good
  20. f1simgames
    f1simgames Member
    516Coins
    Hello ,
    all dash is design by me and it is 3D printed.So it is perfect in T500RS wheel.Noone of shifters hits the dash.
