DIY - Actuator feasibilty
Discussion in 'Motor actuators and drivers' started by devincox, Jan 20, 2009.
  1. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    Hello all,
    Excellent site here, full of great info. I am looking at the feasibility of DIY actuators to help reduce the cost of a 2DOF simulator like bvillersjr's. I have thrown together a drawing and a parts list to see if this preliminary design might be a feasible solution.
    I have posted a very rough drawing to illustrate what I am thinking. I would hope that tronicGR's dual mosfet h-bridge could control the actuator. My hope is that the design would allow the use of different motors to suit the users weight/torque requirements. I also think the stroke length could be varied easily to taste as well.
    picture:
    parts list:
    12 (.500 OD) acme threaded rod - mcmaster.com $11.29 pn: 98935A721 5/8 - 6
    ball screws could be used also, but at a much greater cost
    2 pullies with 2:1 ratio - not yet sourced
    1 belt - not yet sourced
    8 X 2 X 2 aluminum bar stock for bearing blocks and lead nut (2 blocks/1 nut)
    1 Miniature Absolute Magnetic Shaft Encoder $36.00 pn:MA3 <a class=postlink href=http://usdigital.com/products/ma3/ target=_blank>http://usdigital.com/products/ma3/</a> target=_blank target=_blank target=_blank (not shown in drawing)
    1 12 X .750 round tube 304 stainless threaded to mate with lead nut and spherical rod end (extending arm)
    1 spherical rod end - mcmaster.com $9.68 pn: 8405K131
    1 5.5 X 2.5 X .250 flat aluminum plate for support plate for dc motor/lead screw
    I did this quickly, only to see if I was headed in the right direction so please post all constructive criticism,ideas for improvements, mistakes etc.... Or if I'm just way off.
    I have a very complete hobby shop to create the parts. CNC mill, lathe, etc.
    Regards,
    Devin
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    The idea of a DIY actuator has been lurking in all our minds for quite some time. I would love to see it happen.
    I dont't know where the post is, (maybe egoexpress could point it out?) but if I recall, egoexpress examined this subject in detail and I think the outcome was that an actuator with the same capabilities as an SCN5 could not be built for a price that made it worthwhile.
    Also, I'm pretty sure that ACME threads wouldn't be up to the speeds / heat necessary to match an SCN5 (400mm/sec).
    I'm no expert on the matter though. To get your answer, you'll need some advice from egoexpress.
  3. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    @bvillersjr
    here is the post I think you're refering to:
    http://www.x-simulator.de/forum/post9657.html?hilit= diy actuator #p9657
    I was concerned about the acme as well. I found a Ball screw and Nut, that fit this application, that can be had from McMasterCarr.com for under $50.00.
    My total thus far is under $200.00 with the motor and ballscrew assembly and encoder.
  4. bvillersjr
    Ohio, USA
    438Coins
    Thats interesting. Could you please post a parts list with links so I can look over the specs of the individual components.
  5. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    parts list: price part # source
    12 (.625 OD) ball screw $10.00 5966K261 mcmaster.com
    ball nut $28.00 5966K16 mcmaster.com
    1 sprocket 12 tooth $5.00 6793K17 mcmaster.com
    1 sprocket 25 tooth $5.83 6793K4 mcmaster.com
    1 chain - $3.24 6261K281 mcmaster.com
    8 X 2 X 2 steel bar stock $20.00
    1 12 X .750 round tube 304 stainless $15.00
    1 linear bearing $20.00 8974T3 mcmaster.com
    1 spherical rod end $9.68 8405K131 mcmaster.com
    1 5.5 X 2.5 X .125 flat steel plate $11.97
    1 12 long 2 square aluminum tube $9.55
    controller - tronicgr's dual mosfet h-bridge $15.00 tronicgr/mouser.com
    1 Miniature Absolute Magnetic Shaft Encoder $36.00 MA3 http://usdigital.com/products/ma3/
    1 250W 24v 13.3A GEARED Motor $50.00 http://tncscooters.com/product.php?sku=106105
    I believe a cheaper encoder could be sourced or made.
  6. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    Had to change to 5/8 ballscrews to get a cheaper ball nut.
    I dont think mcmaster.com allows offsite links into their product catalog as none of the links would work.
  7. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    Well, do to lack of response and me doing the Wiki editing. This project is on hold. I will however pick it back up, however with a different direction.
    Devin
  8. OscarH
    OscarH Member
    Paris, France
    517Coins
    Just wondering how much is the linear speed for such an homemade actuator ?
    For my own study, a quick and dirty math for 200 mm/s actuator means a rotating speed of approx 8000 rev/minute.
    Decided to give away for the time being.
    OscarH
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi
    Ball screw 5966k261 pitch 13/64=+/-5mm=40x60=2400rpm
    Fore Devin to make it more easy look @ <a class=postlink href=http://www.surpluscenter.com onclick=window.open(this.href);
    return false;>www.surpluscenter.com</a>
    They have a mechanical actuator (ball screw 1/4 pitch) you will find him on MISC.
    Miscellaneous/other number1-3074
    Regards Ad
  10. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    I posted before following Adgun's link to the mechanical actuators, so I had to edit my post.
    Great link Adgun! I bought one of the actuators to test it. I will post back. I was thinking of heading in a different direction but these are so cheap I have to see if they will work in this application.
  11. OscarH
    OscarH Member
    Paris, France
    517Coins
    Me too.
    I ordered 2 * 1-3074 today. This could possibly replace my 2 Renault Clio wipers motors. More design to do...
    It is worth spending 10 bucks to have a try. I'll keep you posted.
    OscarH
  12. RaceRay
    Hamburg, Germany
    23,884Coins
    Interesting ready-to-go actuator. I am curious about the quality of the parts, specially the bearings and ball screw to move the actuator with high cps. For that cheap price it should be worth a try.
    regards, René
  13. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi
    Please add. some picters when hi arived.
    Ad :thbup:
  14. tronicgr
    tronicgr
  15. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    that looks nice too bad theres only one.
  16. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    I was wondering about the quality as well. Even if some of the components are bad, I can probably still use the ballscrew and nut. We shall see.
    Anyways, for 9 bucks, you cant go wrong. They also had some other cool stuff I wanted as well, so it was a good find for me. Thanks again Adgun.
    Devin
  17. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    I received the actuator yesterday. I still need to clean it up quite a bit, but it looks promising. It feels very solid, at least solid enough for my purposes. I now need to source a 40 degree helical gear to mate to the gear on the actuator. Depending on how hard it is to source this, I may fab up a pulley instead.
  18. OscarH
    OscarH Member
    Paris, France
    517Coins
    Got my 2 units this morning. Time to open the box and take pictures. Here they are...
    Look promising. Just need to find out how to stick a motor on it.
    15cm activated lentgh. Not a lot, but somehow reasonnable.
    OscarH
  19. devincox
    devincox New Member
    IT Guy/Programmer
    352Coins
    I am disassembling mine so I can get the old grease out and make it spin more freely. I am also trying to figure out how hard it would be to get the helical gear off so I could put on a cogged pulley and belt setup to fix it to a motor.
    Devin
  20. RaceRay
    Hamburg, Germany
    23,884Coins
