Flightsimulator 6DOF - University of Applied Sciences Kempten
Discussion in 'DIY Motion Simulator Projects' started by HS Kempten, Feb 13, 2017.
  1. HS Kempten
    HS Kempten New Member Gold Contributor
    Kempten, Deutschland
    14Coins
    Hey everyone!
    We are three students who will build a flight Simulation for our university.
    The following requirements are placed on our project:
    • Mobility of the System
    The Simulator has to be designed as a transportable system in order to enable presentations during fairs, lectures, experiments and other Student projects​
    • The following restrictions must be observed:
    mass
    spatial dimension (maximum size 2m x 1.2m x 2m)
    dismountability in transportable components​
    The movement of the platform is to be realized by means of six linear motors, which are arranged in a hexapod arrangement.
    IMAGE-LINK ​
    A comparable project is:
    YOUTUBE-LINK​
    Because of a limited budget we won't do a detailed reproduction of the Cockpit.
    As a simulation software, Prepar3d is used.
    We will probably use the following motor / linear systems:
    DUNKER LINK​
    The motors are controlled via a bus system, called CANopen. There are two possible variants of the structure:
    • Simtools - Serial interface - Arduino / Raspberry, which controls our actuators - CANopen
    • Simtools - program which reads variables from Simtools and which controls our actuators - USB-CANopen Adapter
    Open questions and challenges:
    • What do you think about our linear cylinders/actuators?
    • How do we have to configure the axes in SimTools when using linear cylinders?
    • Is there a way to access the SimTools axes values via a software interface in Windows?
    • is there someone who is familiar with CANopen, or has realized the control via CANopen?
    THX &
    many greetings
    Markus, Magnus, Manuel
    //Sorry, i'm not allowed to attach links. I'll correct this, as soon as i'm allowed to post links in my threads.
  2. Pit
    30,510Coins
    Hi, welcome :) First of all you should dig in our FAQ. This FAQ is full of information especially for beginners. Good luck with your project.
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
