value1
Codemasters Dirt Showdown Plugin 2.0.0.4
SimTools plugin for Codemasters Dirt Showdown
  1. value1
    15,079Coins
  2. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    Hi, I cannot get this plugin to work on simtools 2.0. When I start the game, game manager just stays green. I have patched the correct folder (windows 10 x64) and all my other codemasters games work. Any ideas?
  3. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I would check the IP assignments you have setup in the software.
    Are you using one pc or 2?
  4. Sarge
    - 181Coins
    Thanks for the advice. I'm only using 1 pc so I didn't think ip would be the problem. Every other game works just fine, it's literally just this one I can't get to talk to simtools.
    I couldn't get it to work on simtools 1.3 neither. Same issue.
  5. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Here is what i have in the hardware ini that is in your my documents/my games foler...... upload_2017-1-17_11-57-4.png
    I use 2 computers so that IP address is to my sim controller but make sure motion is enabled.
  6. Sarge
    - 181Coins
    Here's mine;
    <motion enabled="True" extradata="1" delay="1" port="4123" ip="127.0.0.1"/>
    </hardware_settings_config>
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    No extradata line? Maybe try adding that in.
    I can try the plugin with 2.0 tonight.
  8. Sarge
    - 181Coins
    Thanks, much appreciated :) I copied from the xml in error, my cfg.bak file looks identical to yours with exception to the ip;
    <physics environmentalDamage="true" vehicleDamage="true" />
    <input device_type="auto" />
    <motion enabled="true" ip="127.0.0.1" port="4123" delay="1" extradata="0" />
  9. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    k, let me test the plugin this evening and I will report back if it works for me. If not the plugin may require further work.
  10. Sarge
    - 181Coins
    No problem, cheers for your time :)
  11. Sarge
    - 181Coins
    Hi all, I managed to get this working after 2 days of messing around with it. If you have the Steam version of Dirt Showdown, change the showdown_acx.exe to Showdown.exe. The capital letter is important, as it doesn't work without it.
    • Informative Informative x 3
  12. Sarge
    - 181Coins
    Another issue, the plugin for this game seems to break it. Once the game is patched, I can recreate this error every time I complete a race in the showdown tour. Once the race is complete, the game crashes and produces the following error;
    If I unpatch the game for motion, the game works perfectly fine, so it appears that the motion patch is what is breaking it.
  13. value1
    15,079Coins
    I wasn't aware, that Dirt Showdown also has this issue with extradata = 1
    I will have to change back to extradata = 0 :(
  14. value1
    15,079Coins
    value1 updated Codemasters Dirt Showdown Plugin with a new update entry:
    Extradata=0
    Read the rest of this update entry...
  15. Sarge
    - 181Coins
    Thanks value1, played this for a an hour or so this morning, different modes etc, doesn't crash anymore.
