Tri-Motion mit drei 350Watt Wischermotoren im DIY
Discussion in 'Commercial Simulators and Peripherie' started by vsp19, Jan 9, 2017.
  1. vsp19
    vsp19 keep Sim-Racing Gold Contributor
    170Coins
    2DOF, 3DOF, SCN6
    In December 2016, I built a Tri-Motion with Hyperaxis as DIY.
    I am currently building a tri-motion system with three wiper motors 350 watts from SimuKit
    After completion, I would like to compare both systems side by side and report my driving and / or simulation impressions here.
  2. Pit
    30,502Coins
    looks almost fantastic! BTW, from where did you buy these "wiper" motors? These are monster wipers, could be from that big thing on the picture lol :)
    • Funny Funny x 4
  3. MarkusB
    4,215Coins
    @vsp19: I would also like to know where you got these motors from. Can you please provide a link?
  4. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    interested in where to get those engines made several investigations without result only found smaller motors, very interesting project I await developments
  5. Wanegain
    Wanegain Active Member
    Bruxelles
    2,014Coins
    Hi @vsp19 ! Nice project I will follow :)
    Motors are sold by https://simukit.com/
    The motors are tailo made to build motion rig but we are currently out of stock. We have an order that should be available in early March.
  6. vsp19
    170Coins
    2DOF, 3DOF, SCN6
  7. MarkusB
    4,215Coins
  8. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Sure they can.
  9. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    20170206_133018.jpg vsp Tri-Motion
    with Gear-Engine 350 watt plus Springs from SimuKit
    With too long and too strong springs
    With these springs the motion has felt like a catapult
  10. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    the new Tri-Motion Alu Rig with 350 Watt Gear Engine and low Springs
    I created this Tri-Motion myself in aluminum
    The engines are from SimuKit
    The necessary power can only be achieved with springs
    The springs are adjusted to my design and weight
    and the Motion-Profile is optimized with PID settings
  11. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Side by side comparison
    with my two tri-motion systems I designed
    vsp Tri-Motion with 350 watt geared motors
    versus
    vsp Tri-Motion with HyperAxis Linear Drive
  12. vsp19
    170Coins
    2DOF, 3DOF, SCN6
    Conclusion
    side by side test
    and building experience
    The Tri-Motion with the geared motors from SimuKit
    is a cost-effective motion solution with a material insert of approx. 2.000, - € and my DIY construction time of approx. 20 hours.
    But I prefer my Tri-Motion system with the HyperAxis linear motors from Frex. This motion system has significantly more power and is significantly more sensitive.
    However, you have to reckon with a material insert of 4,000, - €.
    The DIY construction time is however significantly shorter with approx. 5 hours
    Keep SimRacing ... with Tri-Motion
  13. Wanegain
    Bruxelles
    2,014Coins
    Hi Florentin,
    I see that you put the springs and that the simulator works correctly :thumbs
    I do not know if the same settings for two different simulators can be used as a comparison.
    On the other hand you made a beautiful realization with our kits, bravo! :)
  14. Thirsty
    Thirsty Member
    Brisbane
    593Coins
    That's a fantastic video...good on you...and cheers for putting it on. I understand you focused on performance so the aspect noise wasn't brought up. I wonder if there's a difference.
    Do you need a separate room for that gear or would you think it is likely that others in the same room not involved in this would be able to cope with that?
    I don't have a smallish maybe 12sqm in mind here, it's more the question if it's possible to place that thing in whatever corner of an open plan living area or if you need to close a door behind it.
  15. Fluke
    Fluke Member
    Stafford, United Kingdom
    822Coins
    Yes it, would be nice to see a noise comparison as well, I get the feeling that the springs alone would add quite a lot. I wonder if oil filled dampers are available that would be suitable.
