3 DOF planing with DC 12 or 24 V gearmotors
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by higgy, Jan 9, 2017.
  1. higgy
    higgy Member
    germany
    318Coins
  2. Historiker
    9,214Coins
    Consider the weight of that design, DC motors are not strong enough without some type of help (large springs, ect) to give heave (all motors lifting at the same time). AC motors are usually used in this type of rig.
  3. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
  4. higgy
    higgy Member
    germany
    318Coins
    Yes, i see this, and they use 350 Watts Motors , so i think
    ( i am not really lightweight :) ) with 800 Watts i can use double weights ...
  5. higgy
    higgy Member
    germany
    318Coins
    but most on this Website i cannott read ( no francaice )
  6. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    What will be the total weight of the platform lift?130kg or more?
  7. higgy
    higgy Member
    germany
    318Coins
    platform = ?? kg i think about 40 ... me 110 :) ...So 160 realwieght will be ok i think
  8. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    i think need used on midlle (centre platform) spring like this
    or used ac motor ;);) and this my platform
  9. higgy
    higgy Member
    germany
    318Coins
    ok, thanks for fast infos :)
    middle spring should be an easy option , and looks like no disadvantages ?
  10. higgy
    higgy Member
    germany
    318Coins
  11. Historiker
    9,214Coins
    That link is dead, doesn't work for anyone. You might send a private message to the original poster.
  12. higgy
    higgy Member
    germany
    318Coins
  13. higgy
    higgy Member
    germany
    318Coins
    One question, i want to buy now my 3 engines, what Advantages / disadvantages have
    Planetary gearboxes, worm or standart gerboxes for a 3dof like this ?
    What would you take ?
  14. Historiker
    9,214Coins
    Hi Higgy, you might read through the FAQ section, this question is well addressed there. And many more, it is a very handy resource.
  15. higgy
    higgy Member
    germany
    318Coins
  16. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    i think maybe you need ac motor for you weight am used ac motor +gearbox 220v50hz 0.55kw gearbox 19rpm(watch for you 30rpm) and strong 160nm . my weight +playwood+ejection seat = 170kg. extencion arms it is 7,5cm ...platform movet perect
  17. higgy
    higgy Member
    germany
    318Coins
    Looks nice :) do you have Pictures from under the platform ?
    I think when 350 W DC are working at simukit, 800W should do,
    because its much easier, with 2 car batteries, and also much much cheaper ?
    Wonder that no one tests this, Motors with enought power DV 24V , 800 W inkl (worm) gearbox i can buy for 260 Bucks.
    inkl tax and shipping so 1000,- + 2 Batterys = 1100 , and you have double power than a simukit ( which i love, but for me to less power )
  18. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    engine to same position like you first post ;;;::))https://www.xsimulator.net/communit...evelopment-with-brushless-motor-arduino.7978/
  19. higgy
    higgy Member
    germany
    318Coins
  20. RacingMat
    21,068Coins
