  1. aceinthesky
    aceinthesky Member Gold Contributor
    Pearland, TX
    387Coins
    153,830Coins
    +11,151 / 57 / -2
    That extra support material may mean that you need to double check the balance of the rig @aceinthesky, as it may be affected.
  3. Andres Castaneda
    Andres Castaneda Member
    Colombia
    310Coins
    @aceinthesky how many buttkickers are you going to use?
  4. aceinthesky
    Pearland, TX
    387Coins
    8 buttkickers
    I put all my gear on there and the balance is pretty good, so I'm stoked.
  5. Andres Castaneda
    Colombia
    310Coins
    What type of amplifier(s) do you have?
  6. aceinthesky
    Pearland, TX
    387Coins
    For the chassis mode:
    Behringer iNuke NU4-6000
    Seat/brake/shifter:
    Behringer EPQ 304
    Wheel:
    Buttkicker single channel amp
  7. DOFreality
    DOFreality Member
    Montreal
    344Coins
    what models do you use and why so many?
  8. aceinthesky
    Pearland, TX
    387Coins
    Butkicker model I use are Mini lfe
    simvibe lets you use 8 transducers.
    4 for the chassis mode, 1 for wheel, 1 for seat, 1 for shifter, I for brake. It's an amazing software and all the transducers have different effects. I can't wait to get it all working together with motion and wind, from sim tools. Just have a have to my welder make a mount in back of rig to add some weights to change cog if anyone with shorter legs rides in the rig and move seat forward. Then I need to disassemble once again and paint.
  9. DOFreality
    DOFreality Member
    Montreal
    344Coins
    hazardic,
    Do you use SimVibe?
    Looks like you have only one BK under the seat?
  10. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    correct there is one under my butt. however i don't use simvibe
  11. DOFreality
    DOFreality Member
    Montreal
    344Coins
    just direct analogue audio from PC is good enough to let it vibrate properly?
    It works with all games?
  12. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    absolutely, i just wanted to get a vibration noise from the road and curbs, something like rumble under the underneath
  13. aceinthesky
    Pearland, TX
    387Coins
    Harzardic, you should really buy simvibe, it's 80 bucks but totally worth it even with only 1 butt kicker. I have one under the seat set up for these effects: engine vibrations, crashes, gear shift and missed gear grind. But you can set up any effects you want , best 80 dollars I spent on my sim. I started with one Butkicker and no simvibe and the vibrations were too muddled.
  14. Andres Castaneda
    Colombia
    310Coins
    I used to have 1 bass shaker under my seat.
    But since I have simvibe connected to it, I have to say that the inmersion is incredible with it. With all the customization you can have with simvibe its a totaly different experience. Its a shame that simxperience doesnt have a trial for simvibe. but is absolutely recommended, in particular with the gear change vibration.
  15. Andres Castaneda
    Colombia
    310Coins
  16. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    i already have it cause i own Accuforce
  17. DOFreality
    DOFreality Member
    Montreal
    344Coins
    Can you try SimVibe and mention the difference?
  18. hazardic
    hazardic m3gt2 fan
    345Coins
    3DOF, Arduino
    well it could be possible but i need a second sound card for it
  19. MacThai_75
    MacThai_75 Member
    California USA
    439Coins
    I'm using my Asus Maximus VII Formula mobo's 7.1 sound, and two Soundblaster 7.1 cards, with SimVibe to drive two Buttkickers LFE's through two ButtKicker 300W amps, and 8 Arua Interactor amps operating push-pull to drive their flat transducers, in various places on my rig, as well as a KOR-FX haptic vest.
    I'll get two more Buttkicker LFE with two more 300W amps when my motion rig gets here.
    Although a single, or even two transducers work well, the additional transducers provide 'much' better defined immersion if placed properly.
    For me that means mounting two of them up inside the seat back in each shoulder bolster, two at lower seat back the lumbar bolsters, two under the seat in each side bolster, one under the shifter, one under the joystick, and the bigger Buttkicker LFEs at all 4 corners of the rig.
    That ... with the KOR-FX haptic vest, work very well for both racing and flight ... especially if (read: when) taking hits from other aircraft, ground fire or flak.
    The seat and vest transducers let you know 'exactly' were you took hits ... just before you respawn. ;)
    Because SimVibe allows you to set up each channel/transducer for whatever specific vibration sensation you want it to be, and allows you to customize that signal in various ways, it all provides a very real and immersive sensation.
    People with motion rigs on the flight sim forums report that it also helps to reduce the confusion that a motion rigs vibrations can induce, that are counter to the immersive feeling when they don't line up with what is happening.
    Kind of like when you watch a video and the audio doesn't sync up perfectly.
    Although the transducers don't eliminate the "vibratory tactile noise" from the motion rig, they evidently help to at least mask it.
    But that is only what I've read, as I'll have to wait until I get my motion rig to see for myself, but fortunately @aceinthesky is moving in the same direction, and should have some results to post on that subject.
    BTW, the Aura Interactor amps and transducers are not very expensive.
    They are actually a defunct haptic backpack that was not well received, so instead of selling for $160, they now go on Amazon for Under $20 ea. ... and as little as $15 at times ... delivered!
    And for our use in strategically placed locations, they are definitely worth it.
    See:amazon.com/Aura-Interactor-Virtual-Reality-Game/dp/B00004UA1I
    When you gut them for their amp and transducer for our use, they look like this ....
    The transducer itself, it's 4 ohm ... in case you prefer to use your own amp.
    They are ~4 3/4" dia. with the mounting flange, about 1" overall in thickness, and have a ~3 1/4" X 3/4" moving piston.
    Overall weight is ~2lbs.
    Top view ...
    Bottom view ...
    This is the Aura amp with it's cover off.
    The rotational controls set the intensity and the frequency bandwidth, with sliding switches for music or game, and normal or A/B operation (for two users).
    But SimVibe does that too (and much better) so I set them for full power full bandwidth, game, and normal.
    But I suppose if you didn't want to add additional sound cards to your PC, and didn't want to use SimVibe, than you could just use the Aura amp controls off a single card by using the proper number of RCA 'Y' adapter cables.
    The Aura amp uses a TIP41B NPN, and a TIP42B PNP for amplification (spec sheet shows both are rated at 65 watts each).
    So the amp operates push pull, and that provides enough punch to the transducer.
    They can be seen mounted against the substantial heat sink at the left of the photo below.
    These are just right to provide the nuance tactile information like shift click, joystick feedback, directional vibration that simulates hits from small arms enemy fire, or gravel/debris and etc. very well.
    But for things like crashes, hitting curbs, or just getting hit by another driver, or ... if in flight mode ... getting B-slapped by an AMRAAM air to air, the ButtKickers at each corner let you know that happened, and exactly where it impacted you. :)
    P.S. If you decide to buy the Interactor, don't be concerned by the number they show in stock.
    They will update it after they run out of that number.
    I understand the seller had/has over 5 thousand of these in their warehouse. ;)
  20. DOFreality
    DOFreality Member
    Montreal
    344Coins
