SCN5 Actuators: 24v 1.5A vs 24v 2A
Discussion in 'Motor actuators and drivers' started by Fahim, Dec 13, 2008.
  1. Fahim
    Fahim Member
    553Coins
    Dear sirs,
    Please see photo attached.
    I downloaded this from the DIY section of the implentation of the scn motion unit.
    I zoomed in very close to this picture and noticed that this power supply used was 24v 1.5A.
    I have noticed it is hard to get (from uk) 24v 2A power supply.
    Everyone suggests after reading some of X-sim threads that 24v 2A is required to power the scn5 actuators.
    If one was to use the 24V 1.5A, would you get the whining noise I heard when seeing your very first youtube clip where you guys for the scn5 working.
    Kind Regards.
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    The SCN5 actuators will make some variation of a whining noise in either case. However, I strongly recommend getting a 2.0 amp or greater power supply. The SCN5's have an internal shutdown if they attempt to draw in more than 2 amps. This means that they can fully utilize 2.0amps safely. At one point, I did not have heavy enough wire ( i used 24 gauge at first) to my SCN5's, and they were not as powerful. I suspect that they need the full 2.0 amps.
    No matter which one you get, make sure it has overvolt protection when plugging it in. I am told that the SCN5's are very sensitive to power spikes and could be permaneltly harmed as a result of one.
    I am using this power supply. http://www.mpja.com/prodinfo.asp?number=17429+PS Unfortunately they require a $100 minimum order for international orders. You may be able to call their 800# and negotiate this.
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    I am really curious how you have been able to see a 1,5A on the label :lol:
  4. Fahim
    Fahim Member
    553Coins
    Dear sirs,
    I zoomed in very close. Then I inverted colour.
    It says 24v 1500ma which I think is 1.5A.
    I will try look for 2A as it says in the DIY section. But if I get a higher one like you guys say, maybe that is for the best.
    Kind Regards.
  5. egoexpress
    422Coins
    Good job! Have to bear that method in mind.
    Regards
  6. Fahim
    Fahim Member
    553Coins
