Actuator or motors ?
Discussion in 'DIY Motion Simulator Projects' started by Artistichalo, Sep 9, 2016.
  1. Artistichalo
    Artistichalo Member
    South Florida
    511Coins
    Hello everyone I'm new here and want to learn and eventually build my own 2 DOF motion simulator . So first question what gives a more accurate representation of what you see on screen actuator or motor ? . Sorry for asking this question most likely already posted somewhere on this sight if so please direct me. I am trying to build something like the Sim Experience Stage 1 . I made my first post in the misc. section so that post is really my first question. I'm was trying to find a parts list for my DIY journey.
    153,938Coins
    +11,158 / 57 / -2
    Actuators are more efficient by design than DC motors with worm gearboxes and some members have been building their own: https://www.xsimulator.net/community/faq/diy-linear-actuators.248/
    Both actuators and commercial SCN actuators will work well, but depending on design powerful DC motors are much much cheaper than SCNs, are much much quieter than SCNs, are not fragile like the SCN pins, and can be much faster. Personally for a first project I would recommend powerful DC motors for those reasons.
  3. SeatTime
    Well this is what I thought as well, but as shown in this thread https://www.xsimulator.net/community/threads/scn5-strip-n-clean.9041/ SCN actuators use a acme thread which has a similar efficiency to a DC motor with a worm gear (around 40-5o% efficent). Not at all like the DIY actuators that use ball screws (around 90% efficent).
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    They use Multi start acme screws in scn5, they are more efficient than single start screws
    But it won,t be more than 65%
  5. SeatTime
    Thanks all good information. I don't own SCN actuators, so was just going on what I could make out in the 'SCN5 strip and clean' photos, for the money just always thought they were ball screws.
  6. Rudolf Jan Horak
    Rudolf Jan Horak Member
    Simulator Maintenance Student
    Devils Lake, ND
    274Coins
    Motion platform
    Our sim project is looking at using winch motors, which is another option. A lot of the projects on here are lifting only a light cage where we are lifting a 9o0 lb cabinet add to that the weight of the player. The hardest part for us is to get something that is not over kill or worse something that is too weak to maneuver such a heavy device.
  7. SeatTime
    900 lbs +, I would be looking at AC motors/inverters and suitably rated gearboxes, but if you must, recommend purchasing just one winch motor, controller, driver, power supply etc and test it for speed/load and inertia moving capabilities.
  8. Rudolf Jan Horak
    Devils Lake, ND
    274Coins
    Motion platform
    Thanks Seat time, I appreciate any and all inputs. The problem is we are a school and a state one at that. This means that if you are working on a project to any level, you have to provide the entire cost associated, you also have to order all the parts. This is not the best approach and if I was funding this myself I would not do it like this.
    153,938Coins
    +11,158 / 57 / -2
    If you can't test for load carrying capacity because of the school funding restrictions then I would say @SeatTime is right, given the anticipated load it would be safer to go down the AC path: https://www.xsimulator.net/community/faq/vfds-and-3phase-motors.9/category
