[DIY] OpenSimwheel.NET | Selbermacher Servo-Lenkrad
Discussion in 'DIY peripherals' started by bberger, Aug 13, 2014.
  1. LI JIAN HUI
    LI JIAN HUI Learn 2DOF maker
    CHINA
    351Coins
    2DOF, DC motor
  2. Nick Moxley
  3. LI JIAN HUI
    CHINA
    351Coins
    2DOF, DC motor
    I sincerely hope the stepper motor , and that is the most cost-effective to , for me
  4. Martin Bell
    Martin Bell New Member
    287Coins
    Hello All. New here. I would like to build one of these units as a demo project for my work. As a supplier of motion control components, I would like to use our own components whereever possible.
    Has anyone used this system with a servo drive with analogue control or any of the industrial field bus systems?
  5. Tomsix
    Tomsix Member
    Németország
    324Coins
    That servo is too powerfull for home use i think I see a lot of people with broken arms and fingers :popcorn
  6. Nick Moxley
    Do you Instinctively Stick your Head in the steering wheel spokes when you have an accident.....No you sure as heck dont. As Im sure many wouldn't do. Would you potentially require a liability waiver for a OSW in public, sure....but Broken arms and finger's are a Bit over exaggerated. No one has ever reported having been injured really. Or at least not on any of the major forums.....and In reality if you did hurt yourself, There's only One person to blame, the guy Holding said wheel.
  7. Pit
    30,503Coins
    I know from one accident only when a (dump) osw user flashed Granite while the osw was on (full powered). After flashing he touched the wheel and it began to spin like hell. One finger was heavily injured. AFAIK he was a few weeks off (from the wheel lol)
  8. TOPMO3
    TOPMO3 Active Member
    Russia
    896Coins
  9. Nick Moxley
    In the initial setup i had one check box that got left unchecked and also had the 1000rpm run away. I guess some people are just bound to hurt themselves no matter how safe you make it.
  10. ahoenksiluman
    ahoenksiluman Member
    indonesia
    89Coins
    hi all..im new hre..i planning build DD as cheap as possible using china part...
    i find a servo driver look like argon driver in china website (lichuan b2 servo driver maybe you can search them)...in case if i use them, how i can install the firmware.??
    probably somebody here can explain or have experience with china servo driver...
