2DOF Aluminium Profile Rig
Discussion in 'DIY Motion Simulator Projects' started by stevemontuno, Feb 1, 2016.
  1. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Had to disassemble my rig this week to reposition the seat on the U-joint for better balance which also meant i needed to realign the motors and frame too,,, was a job that i've been meaning to do for a while though ,, All good now, while i had the frame apart i also added some checker plate to the rig ,,
    I've also been stock piling a few bits and bobs to add a couple more MonsterMoto's and tidy up the controller box and electronics so it all fits neatly under the foot plate , that's the next job.
  2. stevemontuno
    1,461Coins
    @mariano68
    I added an updated Ard+MM winged deck so you can add as many monstermoto's as you like with the Arduino , i also cut the MM decks down so it will fit a MM with a zip tied heat sink,,i just glued the extra MM platforms onto the main deck for 2 monstermoto's either side of the Arduino board but you can position them where you like,,
    Thought this might come in handy for one or two of you guys ,,,, it's on thingiverse here,,,,,,,,, http://www.thingiverse.com/thing:1746224
    The first version is here if you need the ard cover http://www.thingiverse.com/thing:1510217
  3. stevemontuno
    1,461Coins
    Bit of an update ,,,, I've re-wired everything on the rig so it's much more cleaner than before allowing me to put the control box out of the way under the pedal plate ,, I also added a couple more Moto's for 60/120A peak ,,, ( Respect Mr. @Pit ) .
  4. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Thanks very much!
    Really nice xbox :)
    Could you tell me the name of the connectors you used? Are they audio plugs?
  5. stevemontuno
    1,461Coins
    Cheers mate ,,, They are called Aviation Plugs .
  6. stevemontuno
    1,461Coins
    Got the motor cooling fans all wired up and fitted into place today ,,,, i just need to make a nice cover for the motors now ,, plus a few other little bits and then the rig should be done :)
    Few pics of the fitted motor fans on the rig,,,
    • Like Like x 8
  7. BattleGear
    BattleGear New Member
    228Coins
    your rig is so awesome! and i love the idea with the xbox case :-D
  8. stevemontuno
    1,461Coins
    Cheers mate ,, :thumbs
  9. stevemontuno
    1,461Coins
    Well i finally finished the motor cover ,,,, although i'm not too keen on the silver/grey color of the top so i think that is going to change if it doesn't grow on me pretty soon,,, I also removed the wheels from the rig and replaced with chrome feet ,,so my rig doesn't move while driving now ,,,lol
    3.6mm Plywood
    Primer
    Sprayed
    • Like Like x 10
  10. Nick Moxley
    Nicely done Steve.
  11. stevemontuno
    1,461Coins
    Cheers Nick.
  12. stevemontuno
    1,461Coins
    Thought i'd give a little update on my simulator ,,,,
    I converted both my Fanatec rims over to USB using the bodnar board ,,, i already had one bodnar board lying around that i've had for ages so i grabbed another ,, also used aviator plugs instead of the cable gland as they just look a lot nicer,,and plus they are plug and play,,,
    And bullies special prize was i fitted my new OSW to my rig,,,, damn i just love that thing,,,lol
    • Like Like x 6
  13. Nick Moxley
    Little eye candy for ya Steve. :p
    • Like Like x 5
  14. stevemontuno
    1,461Coins
    Hehe that looks badass :grin ,,,, is that one of Steve's masterpiece's
  15. Nick Moxley
    Ya, It is. Your 80-20 upright's are just begging for something like that. ;)
  16. stevemontuno
    1,461Coins
    Yep i might just have to look into one of those when my wallet starts to feel a bit better,,,, Steve's 80/20 rig designs are definitely the best out there.
  17. stevemontuno
    1,461Coins
    I've done a couple of upgrades to my rig this last month ,, nothing much but i didn't like the look of the motor cover and it was really getting on my nerves so i've given it a makeover using 3mm ally checker plate ,,, damn that was some hard work cutting and filing ,,,my hands are very sore ,,,lol ,, also put a monitor skirt on for added immersion ,,, just needs a hood now,,
    Anyways ,, some pics .
  18. noorbeast
    152,595Coins
    +11,087 / 56 / -2
    Nice craftmanship, that really looks impressive :thumbs
  19. stevemontuno
    1,461Coins
    Cheers @noorbeast ,,, means a lot coming from a man of your skillz :)
  20. SilentChill
    20,596Coins
    Great work @stevemontuno I don't know how I have missed this thread ?? I must of been too busy messing with boundary's lol :D
    Seriously it looks really professional you should be proud :)
