  1. andpal
    andpal New Member
    300Coins
    I just got the fan to spin in the Dash output tester in diffrent speeds but nothing in No Limit ? I guess the arduino and mm is connected / installed correct if the Dash output test is working ?!
  2. andpal
    andpal New Member
    300Coins
    Thanks for Quick reply, you are truly heros in here for helping so many.
    I get no data in Dash 1 in GameDash when sim is running ? but it says Game Running !
  3. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,260Coins
    Check that you have the dash enabled in the game manager
    Instructions to do that here https://www.xsimulator.net/community/marketplace/game-dash.76/
    Next, run the game in a window and see if you see values in the dash like this, the value in the out of dash 1 must be UNDER 255. It should be a 3 digit number like 057 or 126, 0 being fans stopped and 255 being top fan speed. If the number is wrong then check the maths, rounding and padding
  4. Avenga76
    Network Engineer
    3,260Coins
    Take a screenshot of your comm settings and you maths settings and I will check them
  5. andpal
    andpal New Member
    300Coins
  6. andpal
    andpal New Member
    300Coins
    The fan is getting stuck when i take to high values in test.. it frezzes and wont stop or speed up.. and I have to unplug the usb Cable to the arduino UNO card to make it stop..
    Maby a Clus.. And I'm sorry I hope I have chosen the correct IP ?.. Taking a screen ump on that aswell
  7. andpal
    andpal New Member
    300Coins
  8. Avenga76
    Network Engineer
    3,260Coins
    For the IP, can you just try the local host IP address 127.0.0.1
    Also try it with just "math * 5" instead of "math *5.0"
    Looking at your first screenshot the maths does look wrong. if you put in a 3 in the tester then it should output 15, but it is outputting 150 so I think it doesn't like decimals
  9. andpal
    andpal New Member
    300Coins
    Iracing is working in Dash1.. something wrong whit No Limit.. no fan actions due.. but will check for furter misses..
  10. Avenga76
    Network Engineer
    3,260Coins
    It will be your maths. based on the first screenshot, "Math * 5.0" actually times it by 50 because it is ignoring the decimal point, that is why when you put in 3 in to the output tester you get 150 out (3*50=150) So you will be instantly going over the 255 limit. It should just be "Math * 5 so you should get 15 in the output (3*5=15)
    For iRacing the in is in KPH so you probably don't need to do any maths unless you are going over 255KPH.
  11. andpal
    andpal New Member
    300Coins
    THANKS ! IT FINALY WORKS AND IT'S AMAZING :D
    Time to try around diffrent setings to tune it in and some sims, again thankt for your time and Quick answers !!
    Cheers, and until next time take care
    / Best Regards Andreas
  12. Avenga76
    Network Engineer
    3,260Coins
    Awesome!! Glad you got it going.
  13. andpal
    andpal New Member
    300Coins
    How noisy is your motors ? My does not stop quick enough !! been trying iracing and just dont get the corner in/out dipp n' speed again from my fans.
    But lives in a appartment and wonder if they will manage.. my simvibe does not make any noise to the people next doors so that works quite well.
    and, i have a 24v car coler fan.. can i plugg it in to the 12v and many just get half effect or will i burn both the arduino/mm and powersupply ?
  14. Avenga76
    Network Engineer
    3,260Coins
    Someone asked the same question about noise over on the iRacing forums so I will post it here
    I did some testing with a little app on my phone, not the most scientific but it might give you some idea.
    This is standing beside my rig, probably about 2 feet away from the fans.
    This is as you come over that first big dip at the start of my video so the fans ramp up from a slow speed to full speed then back down to about 75%
    This is one of the faster sections in the middle of the coaster
    And this is when I switch off the fans. Note: this is with all the rest of my gear off, I have a bucket load of cooling fans on my amps, DIY motion and Accuforce so my normal ambient sound levels with the wind simulator off is around 68dB so the wind simulator isn't that much louder then the rest of my rig.
    130CFM is about half what I am running. At half speed mine probably feels like a strong breeze, like if you were outside and it was that windy then I would probably think it was really a windy day.
    With them on max it is very windy, like you would expect sticking your hand out the window in a car on the motorway.
    I should really get an anemometer so I can test it.
    As for the 24V fans, it depends of the fan, they will have a voltage range that they can handle, say 14v to 27v. 12v might not be enough to spin up the fan. you won't burn out the MM or power supply, the MM and PSU will still put out 12v, all that will happen is maybe 12v won't be enough to spin the fan.
    With the fan ramping down, I guess it would vary from fan to fan and the motor and resistance of the fans. The blowers I have have quite a beef motor and the resistance is quite high, like if you spin them by hand they don't keep spinning like a computer fan does, they stop almost instantly.
  15. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
  16. Archie
    Wollongong, NSW, AU
    3,796Coins
    @Avenga76 - Would you mind sharing your Ebay seller link for the Motos and Uno?
    Knowing the hassle @SilentChill had with bad sellers / stock, it would be good to know a good one :)
    • Optimistic Optimistic x 1
    145,124Coins
    +10,778 / 52 / -2
  18. Avenga76
    Network Engineer
    3,260Coins
    I got them from this seller
    http://www.ebay.com/usr/survy2014
    He sent them the day I ordered them and sent me any email saying they might take 20-40 days to get to New Zealand but I got them about a week later.
    I have tested 2 of the Arduinos and 2 of the MM's are they were both good. I will test the rest when I start my motion upgrade. They all look good from a visual inspection.
  19. andpal
    andpal New Member
    300Coins
    Avenga my setup stoped to run between a reload of diffrent cars in iracing.
    Question if my mm is burned how do i know ???
    game dash is connected to the running iracing but no fan spinning.
    leds are working as they are supposed too
    have i burned out my MM board ?
  20. Avenga76
    Network Engineer
    3,260Coins
    I have had mine stop a few times between sessions. Just try closing game manager, dash and engine, turn off the MM and Arduino. Then start everything up again and test it.
