truck windshield wiper motor
Discussion in 'Motor actuators and drivers' started by engenharia, Aug 4, 2016.
  1. engenharia
    engenharia New Member
    Brasil
    231Coins
    How to eliminate electrical connection to the housing
  2. engenharia
    Brasil
    231Coins
    locate the screw to open the engine
  3. engenharia
    Brasil
    231Coins
    unscrew the two screws
  4. engenharia
    Brasil
    231Coins
    remove the carcass , it seems that is trapped but is only the strength of the magnet pulling the rotor
  5. engenharia
    Brasil
    231Coins
    inside has a plate and 3 brushes. two of them are linked to yarn speed and another is screwed into the housing
  6. engenharia
    Brasil
    231Coins
    unscrew and let loose for connecting a third wire
  7. engenharia
    Brasil
    231Coins
    solder wire and insulate with insulating tape , careful not to let touching the rotor to avoid damaging the cable
  8. engenharia
    Brasil
    231Coins
    in Brazil this engine costs U$ 20.00 and is a cheap alternative. This engine has 180W of power and runs on 12V.
  9. Luc1gnol0
    Luc1gnol0 New Member
    Itala, Italy
    246Coins
    nm?
