Tutorial DIY steptronic sequential shifter
Discussion in 'DIY peripherals' started by RacingMat, Jun 1, 2015.
  1. RacingMat
    20,890Coins
    You wish to have a really immersive shifter? and low cost?
    Why don't you use a real shifter? a steptronic!
    between 30 to 50€
    I followed Akai_fr tutorial as an example
    Here is a "full" steptronic device you can buy on eBay
    559397shifterRacingMatSteptronic12.jpg 639873shifterRacingMatSteptronic10.jpg
    First steps : removing the unecessary stuff
    remove the cables
    471608shifterRacingMatSteptronic1.jpg 502214shifterRacingMatSteptronic2.jpg 497306shifterRacingMatSteptronic23.jpg
    you can cut the cable to ease the removing (optionnal)
    remove the cover
    If you want to clean the insides : remove the axle and be careful not loosing the smal "spring and ball"
    987116shifterRacingMatSteptronic4.jpg 824536shifterRacingMatSteptronic8.jpg 903408shifterRacingMatSteptronic9.jpg 798663shifterRacingMatSteptronic5.jpg
    Once done, you get a rather simple device:
    781201shifterRacingMatSteptronic18.jpg 199544shifterRacingMatSteptronic17.jpg
    Check which wires are connected to the micro-switches inside up and down shift
    (probably one common)
    I used a A-B USB cable and kept this end (in order to prevent any computer connexion) images.jpeg
    You can shrink the overall size by cutting bits
    you can achieve a compact size:
    I fixed the steptronic in the box with screws:
    I blocked the disengagement sequential/manual (tilt left) with a screw (some people don't)
    I covered the box with Carbon look adhesive
    Here is the final result:
    yours
    Mat
    • Like Like x 8
    • Winner Winner x 4
  2. Pit
    30,416Coins
    Great Mat as usual best of DIY thank you for sharing your work :thumbs
  3. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Terrible. Ca doit être super réaliste :thumbs
    Je tenterai bien le coup un de ces 4.
    Tu aurais la référence exact de ce shifter RacingMat ? A moins que qu'il n'y ai qu'un seul model qui s'appel steptronic ? C'est pour pas se tromper de modèle :p
    ________________________________________________________________
    Terrible. It must be super realistic
    You would have the exact reference of this shifter RacingMat? Unless there was only one model that steptronic call? That's not the wrong model
  4. RacingMat
    20,890Coins
  5. leaedman
    470Coins
    OK ! Thanks RacingMat :thumbs
  6. tombo
    tombo Active Member
    2,436Coins
    DC motor, Arduino
    i already have one wired up. Thanks for showing how to remove the not needed parts :) I don't want to dissemble it because i was afraid of losing some springs or so :)
  7. RacingMat
    20,890Coins
    You're welcome guys! :cheers
  8. Helium
    Helium New Member
    Earth
    380Coins
    Nice work. I built one myself using a slightly newer version of the shifter.
    Why did you block the path to the right?
    I use the right position as a 3rd button (most of the time I use it as reverse) and the right front position as some kind of parking position when the shifter is not in use.
  9. RacingMat
    20,890Coins
    It's a good idea as well to keep the right position!
  10. Helium
    Helium New Member
    Earth
    380Coins
    The Shifter is awesome to use and I'm still impressed how sturdy it actually is. It really can take a beating. But to be honest I never used any "gaming" shifter so I have no idea how those would compare.
    But I am sure that it's impossible to get something comparable that cheap. With a bit of patience you can get the newer version of the shifter I used and an Arduino UNO (you need to flash a different bootloader and solder some pins to make it a USB host) for less than 15 €. The newer version looks a bit different though and might not be as well constructed (but still more than good enough).
    I even wrote a sketch to use all possible positions but then realized that it doesn't make any sense because all those buttons are dependant. I implemented it anyway because I didn't want to back down :D.
    You could map less important functions to it (switch headlights on e.g.) but activating the button takes a while (move the shifter to the right and then move it to the desired position. Since I got one with the original "lock-knob" you have four possible positions on the right side) and you cannot shift in the meantime. And you have to find a way to make sure that a button is not pressed if you just fly over the position.
    For some functions you can live with that but a buttonbox is much more comfortable and depending on the arduino you are using you got a lot of pins for buttons left.
    Mine has the part number 1 422 834.
  11. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Nicely done. Im also interested in building a shifter. Im in the process of building my 3dof rig now and would like to know if you can tell me what i need to do electrically (wiring) to hook one to my rig. (schematic with parts list) Unfortunately have have no experience at this point with simtools, (just learning) But on the plus side, I am a industrial electrician. thanks!
  12. RacingMat
    20,890Coins
    you can wire the shifter to many boards it depends on what you plan to have: DIY steering wheel, DIY or Leobodnar pedals, dashboard, dynamic simulator...
  13. Dave Irwin
    Dave Irwin New Member Gold Contributor
    Weirton, WV
    154Coins
    Which driver gets installed when you splice the shifter to the usb cable? How does it know it is a game controller?
    I have already followed this tutorial, but I used a USB Encoder PC to Joystick control board I found on amazon instead of splicing directly to a USB cable. Initially it worked correctly, but after a few hours it has malfunctioned and does not work on either computer I tried. I am going to rewire it but I want to try to directly wire to USB. My concern is that I will have to find a driver to use that may or may not work. Thanks for the help.
    Dave
  14. RacingMat
    20,890Coins
  15. Dave Irwin
    Weirton, WV
    154Coins
    I have a few arduino's laying around, would that work? I have a board that I got on amazon and it works for an hour or so and then it "malfunctions". It has done this twice so far and I am looking to make a more stable solution.
  16. RacingMat
    20,890Coins
  17. Dave Irwin
    Weirton, WV
    154Coins
    Thanks for the information RacingMat.
    I will start by rewiring the board that I am already using. It worked for about 2 hours, so maybe the wires are just faulty. If that doesn't work, I will be ordering the Cthulhu board used in the second link you provided. Thanks for the help.
    Dave
  18. razzor13bt
    razzor13bt Member
    automotive technician, sales manager.
    Durban, South Africa
    393Coins
