SilentChill
Grand Theft Auto 5 (Steam Version) Steam BuildID: 3531026
Sim Tools Game Plugin for GTA5
  1. zigzag49
    zigzag49 Active Member
    723Coins
    Test and also any movement.
  2. SilentChill
    20,588Coins
    Yeah latest version I have it working on 3 PC's here to make sure the pointers are good. I don't know what's wrong :( Will have to investigate more
  3. SilentChill
    20,588Coins
    Just to check have you all put the wow64ext.dll and getbaseaddress.dll in your simtools gamemanager.exe folder ?
  4. zigzag49
    723Coins
    I board not set file like that, and checked yours you know , in case we find them or ?
  5. SilentChill
    20,588Coins
    the 2 dll's are in the plugin zip. they need to be copied into your C:\Program Files (x86)\SimTools folder or where ever you have installed simtools.
  6. zigzag49
    723Coins
    after checking both files was well in simtool file originally , in case I still replace both the plugin, but no movement.
    yet has the development of road games , I understood well the engines mettrent on.
  7. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Yes, but still no luck, and game engine crashing after starting the game.
  8. BlazinH
    16,664Coins
    Not sure if your plugin put them there or I already had them but both .dll's are in my simtools directory so that must not be the issue.
    Edit: Dates on both .dll's are 5/14/16 so your plugin must have installed or replaced them.
  9. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    I just crash my game center when i using new version of plugin
  10. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    Are u all using Steam version? i am using steam version. And when i start up my game, the game center get crash
  11. SilentChill
    20,588Coins
    Ahhh yes possibly steam issue ? Mine is just the download from Rockstar I dont own the steam version :(
  12. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    No crashing for me, just no motion.
    Just to be sure, does it matter if Game Manager is run as admin or not (I know some games require Admin, but I'm not sure if any games require you NOT to run it? Of course i tried both ways, but want to keep from switching back & forth to trouble shoot).
    Steam says my current content BuildID is 1019912
    Does the vehicle have to be in 1st person view for motion to work?
    Ahh, just read your comment about you not having the steam version :( Hope somehow that isn't it :)
  13. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    My also not Steam version. No motion, game manager crash after game start.
    And one more thing, some bad reference on patching info screen.
    And i found what cause "GameManager" to crash,"wow64ext.dll"
  14. BlazinH
    16,664Coins
    @SilentChill Has anyone verified whether or not the 2.0 version of your plugin works? Btw, just downloaded mine from steam yesterday.
  15. Twinsen Yuen
    Twinsen Yuen Member
    IT
    Hong Kong
    288Coins
    Maybe Steam version is diffence with Rockstar version in memory mapping
  16. BlazinH
    16,664Coins
  17. SilentChill
    20,588Coins
    I will have to see if I can get hold of a steam key for cheap and get that.
    It's only thing that is different and change some text int the plugin as I have left remnants of the ED plugin in there
  18. zigzag49
    723Coins
    Silentchill thank you for your help.
    As darkcrayon no just no motion crash.
  19. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    I know you don't want donations directly for making plugins but if there's some way we can cover the cost of picking up a copy of the game from Steam I'd be happy to contribute... Since that'd be an additional expense!
  20. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Might it be some problem in "GetBaseAddress64.dll"? One line inside DLL file looks suspicious.
