DIY actuator
Discussion in 'DIY peripherals' started by Ashraf, Mar 21, 2016.
  1. Ashraf
    Ashraf Member
    1,034Coins
    3DOF, Arduino, Motion platform, 6DOF
    I'm trying to make a DIY actuator, It can be done practically from improvised materials ......
    - the only question to be resolved, is the position sensor, maybe 360*-encoder or multi-turn resistor..., or something else ?
    - what can advise the guru? maybe someone have ready solution?
    Thank you.
    153,830Coins
    +11,151 / 57 / -2
  3. hooshang
    hooshang Active Member
    275Coins
    hello @Ashraf
    as I remember you already have done this using Ultrasonic sensor as feedback
    with @prilad which I was very intrested
    why don't you continiue and develope that project?
    yours
    Hooshang
  4. Ashraf
    Ashraf Member
    1,034Coins
    Hello @hooshang
    - I must say that you have a good memory :cheers
    The fact that the actuator is in the open space ... and while working there somebody can put any foreign objects (between Ultrasonic and reflector) during the operation, so I decided to install the internal sensor just for safety...
    regards, Ashraf
  5. hooshang
    275Coins
    hello @Ashraf
    did you see this.the commercial one, think for Playmotion:
    I don't know if anyone can help for way of using somthing like this
    seems works very smooth
