Roboclaw motor controller investigation
Discussion in 'Motor actuators and drivers' started by Nick Moxley, Mar 4, 2014.
  1. Nick Moxley
    17,056Coins
    Moderator Edit:
    This thread was split, the original thread is in the Market Place.
  2. DigitalCrypto
    DigitalCrypto New Member
    Houston, Texas
    343Coins
    2DOF, DC motor, Arduino, JRK
    I found a supplier for JRK 12v12 at a much better price than on their website. Are they knockoffs? I don't know.
    I'd be willing to order a demo batch and send a few out to a couple senior members to get opinions and feedback.
    Let me know.
    - David
  3. RacingMat
    21,020Coins
    Hi! Could you please share the link? I would like to check the price as I'm looking for trying 24v model if any.
    Yours
    Mat
  4. DigitalCrypto
    Houston, Texas
    343Coins
    I presume you are looking for the 24V12 or the 24V23?
    Here is the link for the Pololu product.
    http://www.pololu.com/product/1379
    I will check and see if I can get that one as well.
    - David
  5. Nick Moxley
    17,056Coins
    I think the Problem with the 24v12 is the amperage, 12A3 vs 30A continous from the 12v12
  6. bsft
    Its just a motor controller with no feedback, good for speed control , but no good for simulator motor control.
    The 12v12 with feedback is the reason its a higher cost. It has feedback built in. This one does not.
  7. RacingMat
    21,020Coins
    Thanks @bsft
    Yes, you have to look for "controller that can be used with feedback for closed-loop position control"
    In 24V, it would be the RobotClaw serie from Pololu:
    RoboClaw 2x15A Motor Controller with USB (V4) 90$
    http://www.pololu.com/product/2392
    • Simple bidirectional control of two brushed DC motors
    • 6 V to 34 V operating supply range
    • 15 A maximum continuous current
    • Dual feedback inputs for PID closed-loop control : position control with analog encoders or potentiometers
    • USB serial interface (virtual COM port)
    @DigitalCrypto : I'm not sure to understand: you have found a dealer of used boards?
  8. DigitalCrypto
    Houston, Texas
    343Coins
    @RacingMat the JRK 12v12's are reported as original new unused items.
    As reported above there is not a 24v version with feedback.
    I will place an order for samples on tomorrow.
  9. bsft
    Might have to try one, good find @RacingMat
    I emailed Pololu and asked if this might be a 12v12 alternative in 24v. I await an answer
  10. bsft
    the jrks are legendary
  11. RacingMat
    21,020Coins
    Thanks as I definetly want to try in 24V ;-)
  12. BlazinH
    16,650Coins
    This all sounds good @RacingMat ! :) But can you tell us how to use the RoboClaw to get position control please? And what would the code look like to control it? I’ve tried to get a grip on it but it really doesn’t make sence to me how to make this to work with motion simulators. Thanks.
  13. BlazinH
    16,650Coins
  14. RacingMat
    21,020Coins
    @BlazinH : This board has many interfacing modes: maybe it's tricky :confused:, maybe it's simple...
    I would be interested if we can interface it in a straigh way like JRK (as it seems it has PID inside)
    I'm waiting for @bsft feedback before digging more
    Yes in the other post there's a link to a library available for interfacing with Arduino
    http://downloads.orionrobotics.com/downloads/datasheets/motor_controller_robo_claw_R0402.pdf
    Here are other examples from Robotshop.com
    http://www.robotshop.com/content/ZIP/arduino-library-and-examples-b0098.zip
  15. bsft
    @RacingMat , I have not gotten a clear answer on this yet. I emailed pololu , but they just referred me to a link on the orion website.
    As my knowledge of such devices is limited, I have to say I cannot answer this question anymore.
    You are welcome to email pololu yourself if need be.
  16. bsft
    This is the answer I got from Pololu
    "Hello, David.
    Thank you for your compliments and interest in our products. The
    RoboClaw 2x15A can supply brushed DC motors with voltages up to 34V, and
    it features closed loop PID control, so it seems like it might work as a
    higher voltage jrk replacement. The V4 versions of the RoboClaw do have
    a USB interface that lets you do position and speed control by changing
    PID parameters, and it looks like you can control the motors directly
    through the same interface. So, I don't think an external
    microcontroller is needed to control it. However, we do not manufacture
    the RoboClaw, so its interface and configuration will be different than
    the jrk's. You can learn more about using the RoboClaw by reading its
    user's manual, which you can find under the Resources tab of its product
    page:
    http://www.pololu.com/product/2392/resources
    Under that same tab, you can also find a link to download the software
    for configuring and controlling the RoboClaw.
    By the way, it sounds like you were using the jrk as part of a
    simulator. If you are currently using some simulator software to
    communicate with your jrk, I recommend checking with the manufacturer,
    Orion Robotics, directly to see if it will work for controlling the
    RoboClaw:
    http://www.orionrobotics.com/Contact-Us_ep_71-1.html
    If someone else can make sense of this, please do. I am too dumb to understand these things.
  17. RacingMat
    21,020Coins
    That looks good!
    It's worth further investigation :D
    Thansk @bsft
    I'll keep you informed
  18. eaorobbie
    20,463Coins
    Another note they are encoder driven for feedback, pots are not supported.
    They do look rather tricky to setup. Using an Ard would defeat the purpose of using them.
    Goodluck.
    @BlazinH these are a new version the old one could not be driven directly from USB and had some major bugs.
  19. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,108Coins
    Interesting, many of the interface details in the manual are very similar to the sabertooth 2x60. I suspect one of the products was made to be compatible with the other at least at the interface level - can't comment on the driver itself.
    Sabertooth Simple Serial matches Roboclaw Standard Serial, the packet serial modes appear the same for both, both have an RC and Analogue mode. Roboclaw has the added feature of USB though.
    Not sure they are really suited to sim requirements.
  20. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    Hi
    For questions about the Roboclaw you can try www.basicmicro.com
    They have a special place fore the Roboclaw @ there forum for jears.
