Potentiometers
Discussion in 'Motor actuators and drivers' started by Andrea 1968, Sep 20, 2015.
  1. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,941Coins
    I see they are 5k Ohm and the stander pot resistors that most controllers commonly use is 10k Ohm ...
  3. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    I am not an expert on electronics but I think it's just a difference of current consumption .
    I = V / R
    I = 5/5000 = 1 mA
    I = 5/10000 = 0.5 mA
    the difference and small !!
  4. speedy
    Alexandria , Egypt
    7,941Coins
    Hi @Andrea 1968 ...
    FYI, the choice of the 10K Ohm has nothing to do with the current consumption.
    It is a standard value made many years ago for many appliances as far as my readings based on the best linearity ,best output signal sensitivity plus many many different factors.
    you can read more on this FAQ link about Fundamentals of Motion Control .
  5. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,064Coins
    As long as it is a quality pot, there shouldn't be a problem with a 5K pot. Most issues arise in potentiometer selection where low input impedance is present. The Arduino ADC has a very high input impedance so current draw isn't an issue and the regulated supply isn't going to be affected by a 5k pot so there isn't an issue there either. Linearity differences between a 10K pot and a 5K pot would only depend on quality control from the manufacturer. Sensitivity would only be effected by the amount of turns in the pot and the resolution of the ADC in the micro controller.
    In terms of feedback in motion control you are looking at voltage change and so in a high frequency environment issues would arise if you were to use pots with values over 100K as they start to get really noisy and that noise on the DC signal can get picked up by the ADC.
    A 10K pot is commonly used in micro controller/logic based systems just because it is a common and easily obtained value.
    Most issues with potentiometer selection comes down to sine wave (or any type of frequency source) applications as they change the filter response in the system overall. Issues also arise if your sensing output requires a given amount of current. The value will also depend on your circuit were other values of resistors are used in series/parallel and would change voltage/current values within the circuit.
    • Informative Informative x 7
  6. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    good explanation, as soon as possible and we will try those 10k'll check if there are differences.
  7. pedrono2
    pedrono2 New Member
    czech
    213Coins
    3DOF, Arduino
    please What are the best.?
    the lower the value the better.? Not so burdened Arduino processor
    thanks
  8. SixCyl
    SixCyl Member
    444Coins
    The best result that can be obtained is with better quality potentiometer as possible and not a question of value only.
    Try to write a small code on an arduino board with serial interface and connect a pot in analog pin of your choice and play with it ! If you look at your value in realtime she fluctuate anymore with cheapest potentiometer ! has the quality of the potentiometer depends the quality and the linearity along the range of signal ...
    There are some solution for reduce noise on sensor reading but it's not the subject now. Maybe on another post ?
  9. SixCyl
    SixCyl Member
    444Coins
    But the really things important are the quality before all on the position sensors !
    Better signal = less parasitic fluctation on the seat.
  10. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    @Alexey, Thank you for your explanations
    For my part I have Arduino Due ADC with 3.3V and I already have 360 potentiometers with 340 ° race but 20Kohm
    What do you think of these 20Kohm potentiometers with 3.3V?
    Do you think I would gain an important (%?) With potentiometers for 10Kohm Feedback?
    From what I understood from your explanation is that the noise on the DC signal picked up by the ADC affects so depending on the intensity in the covered pot.
    I saw that you can put a non-polarized capacitor between the negative terminal and the cursor.
    The value that I sometimes observed is 100nF.
    How determined?
    By a formula based on the loss of response time arising from the smoothing of the signal?
    Texte original :
    @Alexey, merci de vos explications
    Pour ma part j’ai des Arduino Due avec un ADC en 3,3V et j’ai déjà des potentiomètres 360° avec une course de 340° mais en 20Kohm
    Que pensez vous des ces potentiomètres 20Kohm sous 3.3V?
    Pensez-vous que j’aurais un gain important ( % ? ) avec des potentiometers de Feedback de 10Kohm?
    D’après ce que j’ai compris de vos explications, c’est que le bruit sur le signal DC ramassé par l'ADC influe donc en fonction de l’intensité parcourue dans le potentiomètre.
    J’ai vu que l’on peut mettre un condensateur non polarisé entre la borne moins et le curseur.
    La valeur que j’observe parfois est de 100nF.
    Comment la déterminer ?
    Par une formule en fonction de la perte de temps de réponse découlant du lissage du signal ?
  11. speedy
    Alexandria , Egypt
    7,941Coins
    @TFOU57 ...
    Can you search in Google for three or four questions at the same time ?
    Why ?
    What language ?
    Elaborate more ?
  12. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    @speedy, Sorry, i'm French and I translated by Google Translate.
    If several questions at once bothers you, I will separate my questions
    Is the use of a feedback potentiometer 20Kohms increases the signal noise ?
    (I already have 20kohms potentiometers on 340 ° and my ADC Arduino Due is 3.3V)
    Texte original :
    @speedy, Désolé, je suis Français et j’ai traduit par Google Translate.
    Si plusieurs questions à la fois vous gêne, je vais vous séparer mes questions
    Est-ce que l’usage d’un potentiomètre Feedback de 20Kohms augmente des bruits du signal ?
    (J’ai déjà des potentiomètres 20kohms sur 340° et mon ADC de l’Arduino Due est 3.3V)
  13. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    I think just 3.3v is low than 5v and noise is the same but in your signal is proportional increased with 1,5 times. Pot is just for dividing voltage.
  14. bruce stephen
    general contractor
    michigan
    9,114Coins
    How the potentiometer is mounted on the rig and the amount of force it takes to turn the potentiometer can also affect performance. I started with very inexpensive carbon film pots. They worked ok with with a little noise pollution to start but wore out quickly. This resulted in oscillation because of the worn pot. So then I switched to cheap wire wounds these worked ok but were harder to turn. The difference resulted in a flex of the mounting bracket which again introduced oscillation. So I finally bit the bullet and ordered non contact potentiometers, also known as magnapots. The best investment, they are about 15.00 dollars each as compared to the others I only paid a couple dollars each for . I have almost completely eliminated oscillation while being able to turn up the power. I use the 8858-6127V1A360L.5FS from Www.mouser.com.
    What I'm getting at is SPEND THE MONEY ON GOOD POTENTIOMETERS you don't have to invest a million dollars but stay away from the cheap stuff.
    • Agree Agree x 3
  15. Alexey
    Adelaide, Australia
    8,064Coins
    Anyone got any links to hall sensor pots/magnepots on ebay? All I seen to get is throttle position sensors on the search returns. I've found them on element 14 website but they are priced at $30. So if i can get them slightly cheaper on ebay that would be great but if not.... Element14 it is.
  16. bruce stephen
    general contractor
    michigan
    9,114Coins
  17. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    96Coins
    Ciao @Andrea 1968. Io ho preso i potenziometri che hai linkato sul primo posto e vanno benone. Puoi dimenticare anche il glifo oscillante :thumbs
  18. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 8Coins
    hola mount 100k potentiometers in error and did not work well simulator. Now with 10k it works fine but the mechanical are cheap. the better the hal. do not?
  19. bruce stephen
    general contractor
    michigan
    9,114Coins
    yes hall is better.
  20. Nick Moxley
    17,056Coins
    Hall effect's are 100X more durable as well. I had a Pot lock up back when i first started and sure as shi* its still alive to this day, and to think back. I had a BIG a** pair of pliers on that sucker to get it turning again but once the flex coupler's were installed it was smooth sailing from there on out. $ for $ Hall effects are 1000% worth the investment.
