Request (Feature) Change the ID of SCN5 actuator with SimTools
Discussion in 'SimTools DIY Version' started by RaceRay, Jan 2, 2014.
  1. RaceRay
    23,875Coins
    Would be good to not have the need to use any third party software to be able to change the ID of the SCN actuators.
  2. Kool7789
    Kool7789 Member
    Macau
    258Coins
    SCN5, SCN6
    id love to request of this software due cant manage my actuator
    thanks
  3. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    89Coins
    • Optimistic Optimistic x 1
  4. yobuddy
    50,284Coins
    Hi fellas,
    I have used the dyadic tool for this in the past.
    The next time I get a chance to play with a SCN5 or 6 I could give it a shot.
    I don't own any to play with at the moment.
    Interfaces will have the ability to do a lot more in the future.
    But I don't want to give anything away just yet... :grin
  5. bberger
    bberger Member
    306Coins
    I think it's less important to be able to change the ID within SimTools rather than make it CLEAR to the user that all IDs have to be set to zero. It's mentioned nowhere, not in the documentation nor in the panel inside GameEngine.
    I just wasted almost an hour figuring out what's wrong and only by accidently finding a Frex sim related posting here in the forums I found out that I have to set the actuator's ID to zero. About a year ago when I first tried SimTools I even abandoned the excursion and went back to using Lince because I was thinking SimTools was buggy and didn't detect my actuators..
    PS: Why do you even require it to be set to 0?! Wouldn't it be easier to just add a combobox/input field to select the ID?! Lince for example does a stellar job at letting you select your actuators and is WAY less complicated to set up. That's how usability should look like.
