Buy Now a Download Plan! -
Recent Activity
Activity stream for all registered members at Motion Simulator Community.
Taf posted a new thread.
Electric Power Steering Motor
Hi guys. Im working on building a 2 dof sim using electric power steering motors (eps). My question is do these motors have ground on...
Forum: DIY Motion Simulator Building Q&A / FAQ
Jun 15, 2024 at 13:27 -
luu trung replied to the thread Bumpy Motion in SMC3.
try setting 20khz and Fpid/9 in smc3
Jun 15, 2024 at 11:52 -
luu trung replied to the thread Is it possible to use 2 Arduinos with 3 IBTs to run on SimTools?.
i think you should use 3 arduino for 6 IBT2. The 3rd IBT in smc3 is 31khz the motor will have noise and whistling while the max...
Jun 15, 2024 at 11:31 -
Radioproffi attached a file to the thread Question Worm Gear Alternative.
In DOF Reality we make it with SFU-gear, but we use motor with E-Brake to prevent free-spin when power off. [ATTACH] You can use...
Jun 15, 2024 at 11:20
yobuddy replied to the thread Tutorial How to write a Game Plugin for SimTools 2.0 - API documentation.
In pic #4, you can see that the functions do not return anything. Returning True may make it work. Btw, there is a v2 version of a mod...
Jun 15, 2024 at 02:36 -
noorbeast rated Employee4Life's post
Winner in the thread 2DOF Steel frame 24v motors.
It actually happened. It is done and working with LFS, ASSETTO CORSA and F1 23 Some fine tuning will be made. Have a look at the video...
Jun 15, 2024 at 01:20 -
Employee4Life replied to the thread 2DOF Steel frame 24v motors.
Jun 15, 2024 at 00:44 -
Sebastian2 attached a file to the thread Tutorial How to write a Game Plugin for SimTools 2.0 - API documentation.
Hi, I'm trying to write a game plugin for a game called VTOL VR (military flight sim built with VR in mind). The game runs a mod called...
Jun 14, 2024 at 22:02
noorbeast rated smitty's post
Winner in the thread Showroom Smitty's Rotary Servo 6DOF build (Complete!).
Projects are never really done, right? I never liked the brakes on the TPR's, so I converted them to load cells like many high-end sim...
Jun 14, 2024 at 19:35
FGR FPV posted a new thread.
Since a few years I'm using my diy 2dof seatmover. I'm happy with the feedback, but there's one issue: Gearlash and the noise that comes...
Jun 14, 2024 at 17:52 -
smitty attached a file to the thread Showroom Smitty's Rotary Servo 6DOF build (Complete!).
Jun 14, 2024 at 15:44
Arazok liked noorbeast's post in the thread Tutorial GameVibe Manual.
So, can I please clarify what is the surround capabilities of your setup, it sounds like that maybe limited to 2d stereo? A cheap 5.1...
Jun 14, 2024 at 15:22 -
dallasflynn replied to the thread Question 2 arduino.
Using a USB hub can sometimes complicate or add an extra layer between the computer and connected devices, which may not be needed.
Jun 14, 2024 at 12:29
