Buy Now a Download Plan! -
Recent Activity
Activity stream for all registered members at Motion Simulator Community.
sallerding rated pmvcda's post Winner in the thread FlyPT Mover.
Hi, Yes, Thanos works with Mover. Any serial output is possible, but Mover includes a dedicated Thanos output. File sharing should be...
May 21, 2024 at 05:46 -
MaxPower replied to the thread Linear actuator using ClearPath Integrated Servo System @ 72V DC.
Goal is to do helicopter sim - plan would be 2020 screws with gearing around 26T on motor and 32T on screw. That would be 812 mm/sec and...
May 21, 2024 at 05:45 -
MaxPower attached a file to the thread Linear actuator using ClearPath Integrated Servo System @ 72V DC.
What do people think of the 110ST-M04030 motor? I see one vendor on AliExpress with it for $1400 delivered to the US for six of them....
May 21, 2024 at 05:38 -
sallerding liked pmvcda's post in the thread FlyPT Mover.
.. Just to add this here: [MEDIA] It's a good explanation.
May 21, 2024 at 05:17 -
noorbeast replied to the thread Question Beginner Looking for 3 DOF Arduino Code with Sabertooth Controller.
While there other code options the modified SMC3 for Sabertooth gives a handy graphical interface for setting the different ports and...
May 21, 2024 at 04:53 -
spikedbat replied to the thread Bug Simtool Crashes - can't install - Iracing ?.
Okay sorry about that. Thanks for moving it.
May 21, 2024 at 04:33 -
Raysinred replied to the thread Question Beginner Looking for 3 DOF Arduino Code with Sabertooth Controller.
Hi, and thank you for the link! This is what I was looking for. I will read through this. Based on what I quickly gathered, I'm...
May 21, 2024 at 03:14 -
noorbeast replied to the thread DIY 2 DOF for Beginners.
You currently have Extra 1 assigned to Axis 1 and I suspect, depending on your interface settings, it should be assigned to Axis 3.
May 21, 2024 at 02:56 -
Yes you would need 2 Arduinos if using multiple Sabertooth, see here re code and wiring:...
May 21, 2024 at 02:54 -
hexpod liked pmvcda's post in the thread FlyPT Mover.
May 21, 2024 at 02:25 -
Raysinred posted a new thread.
Hello All, I'm just starting my journey to build my DIY 3 DOF motion sim. Based on what I have read, I plan to go with an Arduino Uno...
Forum: New users start here - FAQ
May 21, 2024 at 02:18 -
Denis Mowberry attached a file to the thread DIY 2 DOF for Beginners.
[ATTACH] I have updated my default settings but when I go to test extra 1 it is moving motor 1 not motor 3
May 21, 2024 at 01:50 -
noorbeast replied to the thread No movement in Iracing with Njmotion Compact R.
It is now clear there are iRacing plugin related issues post the last iRacing update, so please see and monitor the dedicated v3 Beta...
May 21, 2024 at 00:03 -
noorbeast replied to the thread Bug Simtool Crashes - can't install - Iracing ?.
V3 Beta related questions should go on the dedicated v3 Beta thread, for Dev visibility and resolution:...
May 20, 2024 at 23:23
