Buy Now a Download Plan! -
Recent Activity
Activity stream for all registered members at Motion Simulator Community.
noorbeast replied to the thread No movement in Iracing with Njmotion Compact R.
It is now clear there are iRacing plugin related issues post the last iRacing update, so please see and monitor the dedicated v3 Beta...
May 21, 2024 at 00:03 -
noorbeast replied to the thread Bug Simtool Crashes - can't install - Iracing ?.
V3 Beta related questions should go on the dedicated v3 Beta thread, for Dev visibility and resolution:...
May 20, 2024 at 23:23 -
yobuddy replied to the thread SimTools v3 Public Beta.
I'm getting contradictory results from testers. PM sent...
May 20, 2024 at 22:33 -
yobuddy attached a file to the thread SimTools v3 Public Beta.
[ATTACH] Looks like you don't have any Max/Min values either. I would suggest removing the plugin (little trash can on the games...
May 20, 2024 at 22:16 -
spikedbat replied to the thread Bug Simtool Crashes - can't install - Iracing ?.
I'm having a problem with v3 that when it launches iracing from simtools, it tries to launch it through Stream. I don't run iracing from...
May 20, 2024 at 22:08 -
spikedbat replied to the thread Actuator keeps turning off.
I fixed my rig issues, which was that it would go dead after a minute, was by moving my cockpit back further on the motion platform. Thanks!
May 20, 2024 at 22:06 -
dgiatr replied to the thread SimTools v3 Public Beta.
Axis1a and Axis4a will show the same problem even if I set total % to 100, I mean 50% roll rate and 50% sway (total 100%). If I set...
May 20, 2024 at 20:36 -
GTakacs replied to the thread FlyPT Mover.
So question: I have a 6DOF hexapod and the pedal mount is outside of the actuators but below the COR and the top of the actuators. This...
May 20, 2024 at 19:24 -
Gadget999 replied to the thread SimTools v3 Public Beta.
At the moment I can't get simtools v3 to install. It just hangs
May 20, 2024 at 18:55 -
The port should be 4123 buddy.
May 20, 2024 at 18:23 -
jin ho liked yobuddy's update for the resource Motion Simulation Software SimTools.
Small update to the installer so it works with win7
May 20, 2024 at 16:55 -
Properly signed all files and installer. Plugin Updater now only accepts v2 plugins.
May 20, 2024 at 16:54 -
can I test the new plugin / fix ?
May 20, 2024 at 16:39
