Assetto Corsa problem
Discussion in 'SimTools DIY Version' started by Hobbs77, Jan 27, 2015.
  1. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Games connected and patched but all I get is ramdom shaking not able to capture any real movement. Under tuning center, all the motion #'s are constantly changing even if the cars not moving. Using AC plugin 3034. Thanks in advance!
  2. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Under game manager, I have 2 of the same name games listed and for the life of me can't figure out how to remove one from the game selection tab.
  3. Nick Moxley
    17,054Coins
    For your first question. Pause the game, or hit ESC, that will Pause the motion telem #'s in the tuning window, and As for your 2nd post, Are you sure you didn't try and add a 2nd file to the game path or something. Do both profiles work or just one ?
  4. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    My rigs just shakes ramdomly with AC as soon as track and car load and before I push the drive tab. Push drive tab and still get just ramdom spastic movements even when pause game or until I exit the playing window altogether. I've tried reinstalling sim tools altogether and lost all my other games profiles ect. Spent the better part of last night making all new ones for the other games but can't get AC to work.
    As far as the 2 profiles they are both for AC but had this problem back when there was only one. Can't find them saved anywhere.
  5. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Is anyone running AC with the plugin version 3.0.3.4 ?
    145,124Coins
    +10,778 / 52 / -2
  7. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Thanks for your help,
    Did a complete Sim Tools install again and patched it with AC plugin version 3.0.3.4 because I don't have enough coins to get the newest version. Still no luck. Is anyone else running the game with the older plugins?
  8. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Go get your AC plug-in my friend.
    Tom
    • Friendly Friendly x 2
    145,124Coins
    +10,778 / 52 / -2
    You do have enough coins now, so please go through the procedure and use the latest AC plugin, and let us know how it goes. Can you also post some screen shots of your settings.
    145,124Coins
    +10,778 / 52 / -2
    Great minds :thumbs
  11. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Wow.......I don't know what to say..... except thanks Tom, that was unexpected and extremly nice of you. Just got done updating the rest of my games and thought I would check in....THANKS AGAIN I'm going to see if the new plugin does the trick. I'll let you know.
    Update..... Just realised noorbeast made a donation too! Sorry about that and thank you! Glad I took the time to read those alert update notices.
  12. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Well I'm happy to report that the new plugin has made all the difference.....I've probably spent 30-40 hrs trying to get it to work all because last week I downloaded a program called " Real Head Motion" and it's changed AC for me. So I guess it's been awhile since I fired up this game with my rig.
    Side note.....I'm in my mid 50's and self taught when it comes to the PC. About 9yrs now and I'm a little slow when it comes to figuring things out with all the different software programs, it can get overwhelming at times.
    Thanks again for all your help, generosity and patience, Mark
  13. noorbeast
    145,124Coins
    +10,778 / 52 / -2
    Glad you got its sorted and we all do our best to help out where we can.
  14. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hobbs77,
    Many of us here at the forum, really like to help those who "help" themselves.
    It was a pleasure for me as well as noorbeast............AND, the best end result - IT WORKED TO YOUR SATISFACTION!!!!! Great...
    Tom
    PS......I'm 67, and can't get as much done as I "used" to.......but I'll die trying (and usually have to stay in my easy chair the next day until the ol' body will move again)
    - These young studs here have no idea as most of them, with exception for a few of us, are in mid 30's/40's............
    Just enjoy it while you still have it.........
    Many blessings to all....
    Tom
  15. Nick Moxley
    17,054Coins
    Curious how Real Head motion "changed" AC for you, In a good way or bad way ?
  16. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    Hey Nick,
    The game was basically unplayable for me before I installed RHM. The 2 options that AC gives you "Locked to the horizon and not locked, were just too limited of a choice. The camera in the locked position didn't move with the cars pitch when going up and down hills and in the unlocked position the car stays still and the world bounces/moves instead. But with RHM I can put AC in the unlocked camera option and make the car move to the bumps and react to the enviroment instead of the other way around. Maybe the unlocked camera doesn't bother a lot of people but it would make me ill feeling in just minutes.
  17. Nick Moxley
    17,054Coins
    Interesting Hobbs, I played with rhm a little back when it was first released and did a few of the updates, but it was in its infancy and lacked a few thing's imo. I see its come quite a long way in the month's and might be worth taking a look at again, Does it still require the pie program or w/e ? and is the "pitch" setting still not available in the in car view setup app ? That was rather annoying to be honest.
  18. Hobbs77
    Connecticut, USA
    815Coins
    2DOF, SCN5
    I just messed around with it until I was happy with the results...... I included my settings . Yes I needed to run FreePie with it. I made a startup short cut of RHM and place it on my desktop next to my AC startup for convenience and as a reminder to start it first.
