12V DC Motors with 60:1 Gearbox from Motion Control Products
Discussion in 'Marketspace - Marktplatz' started by Roadster2, Jul 22, 2014.
  1. Roadster2
    Roadster2 Member
    1,194Coins
    Just really a 'heads-up' on the availability of 12V DC Geared motors with 60:1 ratio gearboxes from Motion Control Products. These are going to be ideal motors for sim motion projects :-
    Voltage: 12V
    Current: 23A
    Speed: 65RPM
    Torque: 15Nm
    Peak Torque: 30Nm
    Gear Wheel Material: Delrin
    Price: £65 plus £9.99 delivery
    These are available in both Left Hand and Right Hand Gearbox form :-
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380956910371&ssPageName=STRK:MESE:IT
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=111415229286&ssPageName=STRK:MESE:IT
    I would point out that I'm nothing to do with MCP and I'm not on any sales commission. I just thought that these links would be very useful to members.
    • Informative Informative x 5
  2. ace4042
    ace4042 New Member
    577Coins
    If I wanted to build a 2DOF rig would I buy a left and right hand motor, or just 2 of the same? Just when I thought I had this down, something else to confuse me :) Thanks for any insight you can provide!
    Ellis
  3. eaorobbie
    20,398Coins
    I would recommend a left and right one then both levers will be either on the outside or the inside, keeping things symmetrical is recommended. IMO
  4. ace4042
    ace4042 New Member
    577Coins
    Thanks for the info!
  5. Donnie Leonard
    Donnie Leonard New Member
    565Coins
    Do you offer these in other ratio's such as 25:1 but still in the Right and Left gearbox style's?
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    He said he doesnt sell them just sharing the information.
  7. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I just emailed them for shipping cost and options to the US, I will share back what I hear. Still hoping these will work with my JRKs
  8. bsft
    if they are a 200 watt motor, they will be fine with JRKs.
  9. tombo
    tombo Active Member
    2,436Coins
    DC motor, Arduino
    I've just ordered these and get the datasheet, maybe useful for someone because of measurements.
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    It wont allow me to complete the order because he hasnt provided shipping cost information to the US
  11. bsft
    the motors are pushing the limits of the JRKS, considering most of the time we push the motors about 2 to 2.5 times to rated current.
    A good PID, motor settings and proper profile will help.
  12. kanuk
    kanuk If it ain't moving, it ain't simulating...
    Eng
    Melbourne Australia
    2,380Coins
    Thank you so much for the heads up!
    I have emailed the chap for postage costs to down under...
  13. SeatTime
    28,370Coins
    145,046Coins
    +10,776 / 52 / -2
    I passed on that info to @kanuk in a PM @SeatTime, Motion Dynamics is a much better option.
  15. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Yes @noorbeast , got your info! And @SeatTime I did see the australian dealer for these motors., though at 65 quid IW as thinking they may be cheaper even with postage as the Aussie motors will come to a cost of about 200 each. Now there is a confusion for me amongst all this and that being what are the ratings of the motors themselves, some ahve given me the link as below
    http://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    and then having to buy the wormdrives at 60:1 ratio or do I buy the motor you (@SeatTime) suggested? Are there particular speeds and torque ratings I should be looking at?
    Regards!
  16. SeatTime
    28,370Coins
    Depends on what type of sim you are going to build and the amount of load on the motor. For a seat mover, I use the standard 25:1 gearbox which comes with the motiondynamics cheap 200W motor. The Motor and 60:1 gearbox are dearer if you were going to build a full balanced frame, but it is a better quality motor and all steel gearbox. Although some people seem to be having issues with these higher current motors and JRKs, but I cannot comment as I only have the cheap version (I did although fit a 60:1 steel gearbox to the cheap motor for my heave module - works fine) .
    145,046Coins
    +10,776 / 52 / -2
    It does depend a little on what you settle on as a final design @kanuk.
    You are a big bloke so anything other than a shoulder mount seat shaker and you really will need to look at the bigger motors/60:1 gearboxes.
    Like @SeatTime I converted the 200W motors to 60:1, but that resulted from underestimating the Fanatec controller weight implications on a compact design.
  18. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Thanks guys!
    Well, Considering that my first need is primarily for the use of Elite Dangerous and secondarily a sim for GRID AUTO, a shoulder mounted seat shaker may be in order. It seems to the most efficient of all the designs... WOuld this assumption be correct? And should I start a build thread so I can get q' and A;s answered as I go on this build journey?
    145,046Coins
    +10,776 / 52 / -2
    Yes on both counts @kunuk.
    You will find there is plenty of advice and support along the way.
    I look forward to following your build.
  20. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Perfect! Time to start the planning....
    I'll start a thread very soon...
    Thanks heaps guys!
