Tutorial 12cm 12V 7segments gear indicator with GameDash
Discussion in 'DIY peripherals' started by RacingMat, Aug 30, 2014.
  1. RacingMat
    20,895Coins
    Hi guys!
    I have got a 4 inches 7-segment LED and arduino: let's start a Gear Indicator!
    12cm x 7cm
    The closer specs are these :
    http://www.led-display.cc/Single-Di...4-Inch-Single-Digit-7-Segment-LED-Display.htm
    I bought TPIC6c595 : a power logic 8-bit shift register
    This works with common anode and can sink high voltage (50V and 150mA) http://www.ti.com/lit/ds/symlink/tpic6b595.pdf
    It will need only one resistor per segment (less soldering! than transistor + 2 resistors)
    Here is the schematic between arduino and 6c595
    Some pictures of the protoboard:
    the board lost in the middle of the giant LCD :D
    Here is a video of the arduino driving the display:
    - no Simtools connection yet at this stage
    - only a simple counter
    - using SPI library (faster than ShifOut library)​
    Here is the arduino code
    Code:
    Shift Register Example for 74HC595 shift register by Tom Igoe
    Digital Pot Control by Tom Igoe
    Thanks to Heather Dewey-Hagborg for the original tutorial, 2005
    Thanks to CrossRoads!
    by RacingMat 09-2014
    // include the SPI library:
    #include <SPI.h>
    byte fontArray[] = {
    // dp-a-b-c-d-e-f-g
    0b11101110, // 0
    0b00101000, // 1
    0b11001101, // 2
    0b01101101, // 3
    0b00101011, // 4
    0b01100111, // 5
    0b11100111, // 6
    0b00101100, // 7
    0b11101111, // 8
    0b01101111, // 9
    0b00010000, // DP
    //Pin connected to Data in SER IN pin 2 of 6c595
    const int dataPin = 11;
    //Pin connected to latch pin (SRCK)pin 15 of 6c595
    const int latchPin = 13;
    //Pin connected to clock pin (RCK) pin 10 of 6c595 as the slave select
    const int slaveSelectPin = 10;
    void setup() {
    // set the Pins as output:
    pinMode(dataPin, OUTPUT);
    pinMode(latchPin, OUTPUT);
    pinMode (slaveSelectPin, OUTPUT);
    Serial.begin(9600);
    // initialize SPI:
    SPI.begin();
    // take the SS pin low to select the chip:
    digitalWrite(slaveSelectPin,LOW);
    void loop() {
    for (int i=0; i <= 10; i++){
    delay(500);
    digitalWrite (slaveSelectPin, LOW); // << RCLK line goes low
    SPI.transfer (fontArray[i]); // << SRCLK goes high-low 8 times to output 8 bits of data
    digitalWrite (slaveSelectPin, HIGH); // data outputs change on this rising edge << RCLK line goes high to move data into output register
    What Arduino do you need?
    a small arduino nano v3 is enough
    3€ on ebay
    or on dx.com http://www.dx.com/fr/p/nano-3-0-atmel-atme...-arduino-152052
    Any model fits, you only have to check that there is a USB socket.
    For example, Pro Mini Arduino at 2€ doesn't fit
    as it has no USB port and requires a FDTI cable...
    Pro Mini atmega328 Board 5V 16M Arduino
    1/ Final arduino code
    I'm using a trick to speed up the reading of serial information
    As i'm sending only 2 informations Shift light and Gear,
    i'm not adding 'S' or 'G' in front of data.
    I'm just reading data and if it's below let's say 12, it's a gear value (0 to 9)
    if it's above 12 it's the shift light data.
    that's why I conveniently choose @ and ? ascii characters in GameDash formulaes.
    Let's read this arduino code to figure it out !
    Code:
    #include <SPI.h>
      // dp-a-b-c-d-e-f-g
      0b11101110, // 0
      0b00101000, // 1
      0b11001101, // 2
      0b01101101, // 3
      0b00101011, // 4
      0b01100111, // 5
      0b11100111, // 6
      0b00101100, // 7
      0b00000000, // OFF empty
      0b00000001, // REVERSE SPEED
    byte LEDarray; //computed order that will be sent to the LED display
    void setup() {
      Serial.begin(115200);
      // initialize SPI:
      SPI.begin();
        SPI.transfer (fontArray[9]);  //  << SRCLK goes  high-low 8 times to output 8 bits of data
    void loop() {
    int Gear;
    int RpmMax;
    int Temp; // used if data (Gear and RPMMax) need to be switched
    if (Serial.available() > 1)  {
    //RpmMax indicates if RPM is over the maximum
    //GameDash calculates if RPM is > RpmMax -> false -> GameDash sent ? -> ascii 63 -> minus 48 = 15
    //if RPM > RpmMax is true -> GameDash sent @ -> ascii 64 -> minus 48 = 16
    //hence RpmMax is always > 12
    //and gear is always < 12
    // GameDash sends value from 0 to 8 and replaces Reverse (GTLegend = -1) by 9
             RpmMax = Serial.read()-48;
             Gear = Serial.read()-48;
             Serial.flush();
            if (RpmMax < 12) { Temp=Gear; Gear=RpmMax; RpmMax=Temp;}// data are switched
    //If RpmMax is true, then combine the gear number array plus Dot segment by a logical operation
    //else display only the gear digit
            if (RpmMax==16) {LEDarray = fontArray[Gear] | 0b00010000;} else {LEDarray = fontArray[Gear];}
        SPI.transfer (LEDarray);  //  << SRCLK goes  high-low 8 times to output 8 bits of data
    2/ setting up GameDash
    Screenshot of GTL plugin showing what each data represents in the game
    I'm using only Gear and RPM in this tutorial
    gear : just replacing reverse which is "'-1' in GTL by a single character '9'
    RPM : math calculation to determine if RPM is over a limit or not
    then replacing 0 or 1 by other ascii characters to fit to the simple arduino code
    Now you have everything available to do exactly the same!
    I put some useful links about GameDash in this FAQ
    http://www.xsimulator.net/community/faq/game-dash-app-beta.29/
    3/ Video
    Here is a video showing how well synchronized it is between GT Legends and the LDC display :)
    Thanks @value1 for the plugin and @yobuddy for GameDash !
    :popcorn
    __________________________________________________________
    Can someone help me to setup a "giant" gear indicator ?
    but the LED are 12v driven...
    I have googled some links but too old: some components are no longuer available...
    Do you know how to drive a common anode 12v 7-segment with Arduino ?
    Thanks!!
    Mat
    • Like Like x 7
  2. soraz
    soraz Member
    Noale VE, Italia
    5,158Coins
    have you consider to use a big square 8x8 led matrix link this ? -->
  3. RacingMat
    20,895Coins
  4. prilad
    Dubna, Russia
    9,615Coins
    3DOF, DC motor, Arduino, 4DOF
    @RacingMat , you can try this schematics - one npn and two resistors for any LED segment
  5. RacingMat
    20,895Coins
    Thanks @prilad !
    Good, it's rather cheap: BC547CG 0,11€ + resistors
    I have read that ULN2803 darlington array could work but not sure... R0403636-06.png
  6. soraz
    soraz Member
    Noale VE, Italia
    5,158Coins
  7. RacingMat
    20,895Coins
  8. RacingMat
    20,895Coins
  9. RacingMat
    20,895Coins
    Hi!
    Next steps :
    1/ coding arduino
    2/ testing with GameDash
  10. tadythefish
    tadythefish Active Member
    Process automation engineer
    Slovenia
    676Coins
    where did you buy these giant led segment dislays?
  11. RacingMat
    20,895Coins
    Code:
    #include <SPI.h>
    // dp-a-b-c-d-e-f-g
    0b11101110, // 0
    0b00101000, // 1
    0b11001101, // 2
    0b01101101, // 3
    0b00101011, // 4
    0b01100111, // 5
    0b11100111, // 6
    0b00101100, // 7
    0b11101111, // 8
    0b01101111, // 9
    0b00010000, // DP
    void setup() {
    Serial.begin(9600);
    // initialize SPI:
    SPI.begin();
    void loop() {
    delay(500);
    @tadythefish : I got several of them from junk... you can PM me
  12. RacingMat
    20,895Coins
    :popcorn
  13. value1
    14,509Coins
    Yes, indeed, it's great to see that they all work nicely together!
    Well done, @RacingMat! :thumbs
  14. RacingMat
    20,895Coins
    Setting up GameDash
  15. Matth.Gyver
    Matth.Gyver New Member
    208Coins
    Nice tutorial RacingMat, as usual.
    Is there a list of plugin compatible or we should browse each plugin in the libraryfor get the information ?
  16. RacingMat
    20,895Coins
    I have added the arduino: the tutorial is complete now
    Thanks for the compliment! Hope this help
    Final arduino code
    I'm just reading data and if it's below 12, it's a gear value (from 0 to 9)
    that's why I conveniently choose @ and ? ascii characters.
    Code:
    #include <SPI.h>
      // dp-a-b-c-d-e-f-g
      0b11101110, // 0
      0b00101000, // 1
      0b11001101, // 2
      0b01101101, // 3
      0b00101011, // 4
      0b01100111, // 5
      0b11100111, // 6
      0b00101100, // 7
    void setup() {
      // initialize SPI:
      SPI.begin();
    void loop() {
    int Gear;
    int RpmMax;
             Serial.flush();
  17. RacingMat
    20,895Coins
    I dunno
    Maybe @value1 @prilad @eaorobbie could answer to this?
    I could add the list in the FAQ maybe...
  18. value1
    14,509Coins
    Well, anyone volunteering to compile such a list?
  19. Nick Moxley
    17,054Coins
    Whats this Giant display worth ? ?
    And what are Arduino boards and all the accessories needed worth ?
  20. Matth.Gyver
    208Coins
    I'll do the job ;-)
