driving force GT wiring diagram
Discussion in 'Electronic and hardware generally' started by bsft, Jul 31, 2014.
  1. bsft
    I have done a search with no much success.
    I have a driving force GT wheel and pedal set, where I need to re-wire the pedals.
    Does anyone know of a wiring diagram?
    Cheers, David.
  2. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    15,650Coins
    Found this...
    http://www.gtplanet.net/forum/threads/how-to-connect-pedals-g27-to-dfgt-problem.248499/
    Inside the pedals will be two POTs, one for accelerate and one for brake.
    The center wiper pin of each pot will be connected to the accelerate and brake DB9 pins above and the other two outside pot pins will be connected to +5V and GND (just like wiring the feedback pots on the sim). If you get the +5V and GND backwards it will make the pedals work in reverse.
  3. bsft
    You Beawdy! Thanks mate!
    I will go shopping for a plug tomorrow and revive the ol' faithful.
  4. bsft
    Nope, dammit @RufusDufus that didnt work, the wiring from the circuit board inside is different. Thanks for the help anyway. I will buy a new set and put the others aside till a later date.
  5. RufusDufus
    Adelaide Australia
    15,650Coins
    Bummer... I didn't think the pedals had a PCB in them or are you trying to sort out the wiring at the wheel end?
  6. bsft
    I gave up trying to rewire a plug and dug inside the wheel, to find 5 wires, dammit. 4 wires coming out of pedals.
    No problem, when I have time again I will have another go.
    Thanks again for the help.
    Dave.
  7. RufusDufus
    Adelaide Australia
    15,650Coins
    Next time you try this may help...
    It looks like the extra wire is to "sense" when the pedals are connected. When the pedals are plugged in the sense wire is connected to +5V.
  8. bsft
    thats it! I will have ago again tomorrow
  9. bsft
    Woohoo!!!
    @RufusDufus , only one way to say it, you have helped resurrect the wheel and pedals
    All hail, All hail, we are not worthy , we are not worthy........
  10. drowhunter
    drowhunter New Member
    - 14Coins
    I'm a bit confused. Does the accelerator wiper pin connect to both 2 & 7?
