Tutorial Arduino code for 4DOF and 1 DIRpin Hbridge board
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 7, 2013.
  1. RacingMat
    20,890Coins
    These little thing ? https://www.sparkfun.com/products/9118
  2. prilad
    Dubna, Russia
    9,614Coins
    3DOF, DC motor, Arduino, 4DOF
  3. eaorobbie
    20,398Coins
    From research yes they will help protect the ardunio but not the h bridge, when the motor free wheels it produces a current that feeds back to the H Bridges and cooks them. The Sparkfuns circuit feeds this extra power produced back to the psu, the Jrk does exactly the same thing.
    If a Dc battery is not included in the circuit it results in Heat being produced my the motor driver (recommended by the producers of the cards, an important step most miss), a way of protecting itself, obviously the cheap Chinese bridges don't do this. From my dealings with them I feel this might be the issue.
  4. RacingMat
    20,890Coins
    Thanks for your replies, guys!
    I'll postpone my 3DOF till Spring... and have some fun with my motomonster during this Winter!
    (The worst thing is that there were even no load on the motors...)
  5. merlin salazar
    merlin salazar New Member
    296Coins
    como puedo descargar el x sim profiline
  6. eaorobbie
    20,398Coins
    No XSim here any more mate, Sorry.
    Use SimTools, its total free and can even run internet free for free.
  7. merlin salazar
    296Coins
    me puesdes ayudar con los plugin de rfactor para arduino con simtools
  8. eaorobbie
    20,398Coins
    Are you having trouble getting rfactor plugin to work in SimTools ? or just looking for the plugin?, you will get a lot responses from more members if you please translate to English, Thanks.
  9. davepeebs
    davepeebs New Member
    G.M
    Sydney Australia
    619Coins
    Nice stuff.
  10. S14A elexian
    S14A elexian New Member
    france,corrèze
    374Coins
    qu'elle serait la configuration pour un 4 dof? (shéma plus bas)
    1 Arduino / 4 pololu 755?
    2 Arduino / 4 pololu 755?
    1 Arduino Mega / 4 pololu 755?
    Quelle serait le shéma de cablage?
    possible avec 2 monstermotoshield et 1 Arduino?
    Je vous remercie
    Je cherche, mais je tombe toujour sur des configuration 2dof tres peu d'informations: Sur des 4dof avec des shéma précis
    she would be the configuration for a 4 dof? (schematic below)
    1 arduino / 4 pololu 755?
    2 arduino / 4 pololu 755?
    1 arduino mega / 4 pololu 755?
    What is the schematic wiring?
    possible monstermotoshield 2 and 1 Arduino?
    Thank you
    I try, but I Still falls on very little information 2DOF configuration: On 4DOF with specific schematic
  11. RacingMat
    20,890Coins
    Hi!
    A 4DOF would require either
    - 1 arduino (UNO, nano or MEGA) and 2 motomonster
    or
    -1 arduino (UNO, nano or MEGA) and 4 pololu 755.​
    You have to connect all Ground (arduino, Hbridge boards and pot) together, all 5V together
    and each Dir and PWM to arduino...
    I would suggest you to try to sketch it as a educational purpose! and I'll check that after ;)
    It's much better to understand it by yourself!
    Have a look on Nath's post New Build motion Sim
  12. RacingMat
    20,890Coins
    yes, here it is:
  13. S14A elexian
    france,corrèze
    374Coins
    je te remercie énormément!!!
    je crois que si tu m'apporte le code modifier pour 2 motomonstershield mon sim aura la signature sur la coque du baquet "par racingmat"
    je vais ajouter des ventilateur de pc et dissipateur pour éviter une surchauffe et perte de rendement
    le tout fourni par une alimentation pc de qualité seasonic modifier
    je vais ouvrir un post quand j'aurais toute les pièces
    I thank you greatly!
    I believe that if you help me change the code for my sim 2 motomonstershield will be signing over the seat "by racingmat"
    I'll add pc fan and heatsink to prevent overheating and loss of yield
    all provided by a pc quality Seasonic power change
    I'll open a topic when I have all the parts
  14. RacingMat
    20,890Coins
    Great! ;-D
    I'll write it next week, i'll be on holiday!
    Mat
  15. Joel
    Joel New Member
    273Coins
    4DOF
    great project!
    could you please send me the arduino code?
    greetings
  16. RacingMat
    20,890Coins
    As @S14A elexian didn't came back on the forum, I haven't written the code... and spent time on other subjects!
    Sorry
  17. Joel
    Joel New Member
    273Coins
    4DOF
    do not worry. I am working in a 4dof.
    greetings
  18. wallytattoo
    wallytattoo New Member
    383Coins
    hi, what is or where i can get the code that I have to download the arduino
  19. RacingMat
    20,890Coins
  20. AlexinChina
    AlexinChina Member
    China
    371Coins
    Hello!I was a novice, can you placed complete code as an attachment here? Thank U!
