I am New to DIY sim building. Anyone chiming in with help is great.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by james wheeler, Mar 17, 2014.
  1. eaorobbie
    20,400Coins
    My humble apologize my friend, Skimmy through didn't not pickup you were talking about a pair. DOH! :oops:
  2. james wheeler
    james wheeler Active Member
    216Coins
  3. BlazinH
    16,575Coins
    Thanks for the clarification Robbie! I try to give the best advice I can so I was curious if I missed something that would allow a different hookup with these. Some motor controllers allow for a master and slave configuration also. Since we all learn from each other, if there is more for me to learn about something, I am eager to accept it!
  4. BlazinH
    16,575Coins
    I think this is the code you require @james wheeler http://www.xsimulator.net/community/marketplace/arduino-code-2dof-and-2-pins-direction-hbridge.67/
    Just one thought. This may a little easier to set up with a shield and a dual motor controller than using the individual ones. However, if you fry a mosfet or something on one of the channels then you will be looking at replacing a dual controller vs only the single one that's bad. The dual appears to be almost exactly double the price of the single so their is not a cost benefit in going with the dual.
    Also to try to find things on this website google xsimulator and what you are looking for. I googled "xsimulator arduino 2 pin" to find this code for you. It was the first link I got after the sponsored ones.
  5. Historiker
    9,176Coins
    Prilad's, Rufus Dufus' and RacingMat's codes all use 1 pin or two pin.
    All three work well, I have used them in my builds.
    Currently using Rufus Dufus' code as it has a nifty tuning utility and can handle three motor controllers.
  6. james wheeler
    216Coins
    the boards are here.:) IMAG0903.jpg
  7. james wheeler
    216Coins
    BlazinH I took your advice and bought a uno and the pololu vnh5019 sheild. now lets get them working. they just got here so now the code. i did check the link you provided but was it ment for a shield or my origional idea?
  8. james wheeler
    216Coins
    OK i have gotten this far building all the hardware and wiring. The only thing I am not sure of is the pots wires.
    this is just a test bench (although its a old record screwed onto a couple of 2x4s) in a sence. I will rewire everything when i bolt it to the frame. Once I learn how to wire the pots I can move onto code.
    My power supply at the momment is still my old 19v 5 amp laptop power. will this effect the code at all?
  9. eaorobbie
    20,400Coins
    Ah none of the Ard code is setup for stacking like you have, unless changed recently.
    Pots signal wire goes to the Analog pins on Ard and +ve and -ve go to 5v and gnd respectively.
  10. james wheeler
    216Coins
    is pololu motorboard not a threw way for the signals from the pots? you are saying i need to connect the pots directly to the ard. i assumed the siglals would relay through the pololu to the ard. they can bedissasembled and wired sepertaly but i wanted to avoid as much solderimg as possible.
  11. BlazinH
    16,575Coins
    The code I linked to above shows to hook up the ard like this:
    Arduino /..Motomonster1
    ......GND <-> GND pin
    ........5V <-> 5V
    .....pin 4 <-> pin 4 inA motor1
    .....pin 5 <-> pin 5 pwm1
    .....pin 6 <-> pin 6 pwm2
    .....pin 7 <-> pin 7 inA motor2
    .....pin 8 <-> pin 8 inB motor1
    .....pin 9 <-> pin 9 inB motor2
    If the vnh5019 motor driver has the same pin mappings as the Motomonster then it should work stacked with the code used as is. If the ards pot input pins used in the code are available on the sheild, then I think you could solder them to the sheild instead of to the ard. However, if the pin mappings are different than above, you will either have to separate the shield from the ard and wire unstacked, or change the code in the ard so it will use the correct pin mappings for the vnh5019.
    btw. I recommend going with the single motor drivers, not the dual! Then if one channel goes bad you would only have to replace the bad one at half the cost of replacing a dual controller.
    Disclaimer: I'm not a arduino user so I might have got something wrong but this is how it appears to me.
  12. eaorobbie
    20,400Coins
    Sorry @james wheeler none of the existing code supports the driver being plugged in the way you have it, you need to make connecting wires and have the two board separate.
  13. james wheeler
    216Coins
    using this image
    from pololu and blazinh pin lay out I hooked them up seperate but I think somehow the conntroller is dead. B4 I was getting a green and red light on either side of the hook ups for the motors but now there is only a blue light meaning that the power is on sheild connection.jpg
  14. eaorobbie
    20,400Coins
    To test the controller flash it with the blink tutorial within the Ard IDE and you may find its all ok. Not sure if @BlazinH has used this driver or code personally, I wouldn't.
    Prilads or RufusDufus is by far easier for a newbie to MC to setup and get running.
    The apps they have makes it nice and easy to setup, where as the other you have to manually edit everything , a headache and a pain for a newbie.
  15. james wheeler
    216Coins
    Are you refering to the pin 13 blink tutorial found on the ardino site? how do i use that to test if the pololu motor controller is working?
    where do I find rufusdufus
  16. eaorobbie
    20,400Coins
    Ok you need to upload the sketch to the Ard. then wait a few secs and the red led , default set to pin13 will beat like a heartbeat, if all good then re upload the motion code and all is well with the Ard.
    Its just a basic test to make sure the Ard is functioning and not about the motor controller.
    1.Connect the Ard to the Usb Port.
    2.Open the Ard IDE
    3. File - Examples - Basics - Blink
    4. Tools - Board - make sure the right board is selected.
    5. Tools - Serial Port - make sure the right serial port is selected.
    6. File - Upload.
    Once finished uploading the red led will blink like a heart beat.
    This confirms the Ard is ok.
    Now repeat the process and open the motion code you wish to run.
    Now from there you need to follow the code writers instructions to get it to run properly.
    RufusDufus code and instructions and nice little setting up app can be found here,
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    As you want 3DOF this is exactly what he has built it for.
  17. james wheeler
    216Coins
    @eaorobbie can you please just confirm that I am starting to figure this out.
    using the written pin diagram and the vnh5019 picture above I am assuming that this is how the modified wire hook up should be laid out.
    arduino => pololu vnh5019
    pin 4 => pin 2 m1inA
    pin 5 => pin 9 m1 pwm
    pin 6 => pin 10 m2 pwm
    pin 7 => pin 7 m2inA
    pin 8 => pin 4 m1inB
    pin 9 => pin 8 m2inB
    5v => 5v
    GND => GND
    POTm1 => A4
    POTm2 => A5
    I have been reading the link you sent me and if this is correct I will start putting the power to it.
    The motor controll board seems to be working. At least the lights are on/
  18. james wheeler
    216Coins
    I have looking at the rufusdufus code and I am stuck at the first part. I don't know what is is i am needing to do to edit the code for mode 1 or 2
    Do I add something in or delete something. I downloaded scm3 v0.6
    I cant use the software till I install the scetch.
  19. BlazinH
    16,575Coins
    The pin mapping modifications you made appear to be correct if you want to use it as a shield. However, if you are not going to stack it (as recommended by eaorobbie) then you can use the general purpose pins [1 in pic] on the vnh5019 to wire to instead.
    Also, while your probably excited to get up and running, I recommend you try reading post here a little more thoroughly. Not only did I recommend going with a single, not a dual controller; but also I stated the pin mappings I posted would only work if the monster moto and vnh5019 had the same mappings.
    And as stated earlier, I am not an arduino user! Just trying to help out if I can. But I would rely more on the arduino experts here than myself! Good luck getting going!
  20. james wheeler
    216Coins
    after rereading you post again earlier i did notice that i took your meaning in reverse of what you said and that pushed me towards understanding that shields are not universal. thank you for taking the time to look over my guessimations. i am probably out of my leage since I have no training in this field but with all the helo i am getting from everyone I am going to at least get up to bat. Thanks agin
