Here is the first official release of GameDash 2.0!
With a faster processing engine and a greatly refined editing system that’s sure to please.
And even a few tweaks to make it easier to use. (Like green pen tops when there are edits)
It will be very familiar to those who have used GameDash in the past.
- Faster processing engine
- Refined Editing and Command System
- New Clamp Command (keep value within a set range)
- Support for up to 3 Output Interfaces.
- New Virtual Output Interface. (Making troubleshooting much easier)
- Can now be used from any PC on your network (set IP’s as needed)
- GUI Refinements to make your Edits easier to spot.
GameDash 2.0 now supports up to 3 Interface outputs!
Enabling fancier and more complex setups!
GameDash 2.0 now has a new Virtual Output interface.
Now you can easily see and log everything that is sent to an interface for easy troubleshooting.
Get your GameDash On!
Tip #1: Use 50ms output rate for the Virtual Output Interface.
(It’s plenty unless you really have a reason to go faster.)
Tip #2: When possible, the software/hardware you are supporting should be written in a way that it drops incompatible commands. This way you can configure new game edits without locking up your device.
- Game Dash v2.3 Jun 25, 2019
- Game Dash v2.2 Sep 26, 2018
- Game Dash v2.1 Nov 17, 2017
